If you're new to knives, I question your choice of a Strider SNG. As someone else once said, high end knives are like fine wine, an acquired taste. If you get a top-of-the-line knife as a first or very early purchase, every other knife afterwards might not seem up to snuff unless you only buy Sebenzas and XM-18's.
I also question the tanto style blade, as it seems to have an utter lack of utility. If I understand correctly, the shape is specifically to create a wider wound channel in a target. I have 2 Emerson CQC Super-7w with tanto chisel grinds, and both of them had their tips snapped off at one point or another(still haven't gotten around to fixing them). Also, I find the perfectly straight edge to be somewhat annoying when trying to slice something, as that shape is NOT meant for slicing. Whether in SD or Every Day Use, the lack of belly for slicing motions is a hindrance.
I might actually suggest the ZT 0300 series, which are a Strider collaboration, also uses S30V steel, has a titanium framelock with G-10 3D scales, uses Assisted Opening flipper, has Tungsten DLC coating on the blade, and costs about half as much. The blade shape has lots of belly for slicing, but the tip is extra thick for stabbing and light prying. The only real catch is that it would be tricky to sharpen a recurve if you don't have the proper tools.
