Well, I just made a pretty good mess of a Ti liner that had a lot of work into it. Making a folder with bearings for the first time and had gotten an interchangeable, piloted counterbore a while back, knowing I wanted to have it for the future. Using it on steel went okay. Then, I went to my Ti liner. That went less okay. Long story short, I got it too hot and mangled it.
So, which counterbore do you use? This one was a somewhat cheap cobalt one with an interchangeable pilot. Do you guys like to have a carbide tipped one? They’re pretty dang expensive, which made me think that’s how I ended up with the cobalt one.
I remember seeing a thread a while ago where someone used an endmill or something similar to spot the location for the pivot, then swap out with a 3/8” endmill, in effect making a work around for the piloted counterbore.
Last, any suggestions on the best way to counterbore Ti? Do you like to use oil or some sort of coolant? Does it depend on the material of your endmill/counterbore? Thanks in advance for any help.
Jeremy
Jeremy
