Which dagger???
on_the_edge
I know Kabar just came out with one that looks pretty reasonable for the price. Case also has one, though that is VERY rich for my wallet. So...max is $150 to spend on a quality dagger. What would you guys recommend? I want quality obviously, but I also want to feel like I am not overpaying to get it. I assume that is possible with $150, so what sayest thou???
Take up pig hunting & stab away. Svord Deluxe Pig Sticker & Hog Beater
http://www.svord.com/index.php
I like the appeal of dagger's and even carried one for a while but I find it really hard to not throw them :D
My first recommendation would be the new EK KA BAR, but you already mentioned it :)
I have a Cold Steel Counter Tac 1 that has survived having the tip reground it 4 or 5 times now. Its nice and balanced, and I believe I picked it up on sale for $70.
The SOG pentagon series ain't bad in the hand. I personally have no experience with them other then handling them in the store.
I've had some daggers that fall in your price range.
For a long time I had a Gerber Mark II. It was an old Vietnam era piece, and it was well used. I wish I had it back, it was great.
I bought a Boker Applegate / Fairbairn that was awesome. They make a set of neoprene trainers for it. Back when I was still doing martial arts I had considered getting the trainers and mastering the old Boker, but I never did. Got rid of it.
On the smaller side, CRKT makes a copy of A.G. Russell's Sting. It's shorter than the others, and only 4 ounces so it's much easier to carry. Little brother really liked it, so I gave it to him.
CRKT also makes a different version of the Sting, the Sting 3B. I've never owned one, but the size and configuration are similar to the Sting, but weighs half as much so I'd imagine it would be a dream to carry.
That's exactly what I'm on the Hunt for as well, a Dagger, unfortunately I feel the only one that will actually do it for me I'd the Spartan George V14 Dagger at $445 bucks, and at that price, I'm just buying more firearms
Gerber makes a small 4" dagger in s30v, but I can't remember the name. I've looked at it before
About $100 with a plastic sheath. ETA: It's called the "De Facto".
I have always loved the dagger shape. As far as production daggers goes the Cold Steel Taipan is about as good as it gets IMO, the MSRP is $300 but you can generally find them for far less. It's got great grinds, sandwiched San Mai steel, it's a bit larger than most daggers, it's just all around cool. The Sting is nice but much smaller, I have not had much luck sharpening it but it would be far more concealable.
The dagger's biggest advantage is its extremely low weight because fo the double grind, and the best way to exploit that advantage is carrying one on a shoulder harness, which also fits with the self-defense purpose... For these reason I would stay away from any bulky metal on the handle... Most are dull but the easiest to re-grind sharper (in terms of geometry, as it was horribly dull) was for me the Cold Steel Peacekeeper I. 7.6 ounces... An even lighter one would be the Junglee Waterloo, 6.8 ounces, but the poor loose leather sheath -which looks nice- is so loose it will have to be replaced... Sharpness is low but improveable on that one. Both discontinued. The Al Mar Shadow is huge at 7.75", and still incredibly light at under 10 ounces: Its point tends to be fragile however... I would say it is the most spectacular and well designed production dagger of all time, particularly the handle. All those are Seki-city made and discontinued: All daggers of Seki-City origin will tend to look crisper and nicer, without blowing up the bank, unless you get in a bidding war on Ebay.
Avoid at all cost the expensive Extrema Ratio daggers, as the handle is just held by a system that is simply crap: See youtube's "Black or darkforestghost(?)" review, he gives it a zero after breaking it completely in 2-3 throws on wood...
Out of the box sharpness per price you might be happiest with Cold Steel's Taipan, but it is expensive and much heavier in the handle than the similar Peacekeeper (maybe the Taipan has a better initial edge, but I can't absolutely vouch for that: Most daggers need heavy re-profiling). The handle ergonomics are well below the cheapo Peacekeeper, but I kind of like the leather sheath, if not the bulky, heavy guard.
The only available dagger that as sharp or much sharper than any single edge knife is the Randall Clinton dagger: 0.4 mm edge bevel, on hugely deep hollow grinds! I recommend the supremely ergonomic finger grooved version, but all are much heavier than 10 ounces: It is so well profiled that it has a true dagger point, yet outslices by a huge margin most single edge fixed blades, and for its length it can even out-chop most fixed blades in wood (I know this sounds unbelievable, but it's true). A true "survival dagger"... I have one, I have no idea why, but I love it.
I would avoid the Gerber range like the Command II and Mark II, because the aluminium handle adds a lot of weight. The narrow blades are a detriment to geometry, but note the "Special Edition" 25th anniversary Command II are ground to a sort of "zero edge" that is viciously sharp... Not a true double edger however. If you want a Mark II I can only recommend the gray handled "Cutlery Shoppe" specials of the 1990s, as they had raspy handles and were much sharper. Note the Mark II is not a Seki City level quality, and this means the center grind is not a perfect straight line by a long shot...: That is why I tend to focus on Seki-City made daggers, but note even the one Al Mar Shadow I got was way off center, so look hard at the photos... I would not get any US or Taiwan made Cold Steel daggers, as they are just bead-blasted or painted, and just way cheaper feeling, but that's just me...
Gaston
I would second that CS Taipan but it's quite expensive and with a 7 1/2" blade a large dagger. CS discontinued the Peacekeepers.
The Gerber Mark II is a classic with it's 6 1/4" blade. Although the current version has serrations, it's really legendary from it's popularity in Vietnam as well as the classic mess hall scene in te 1986 move "Aliens". Many daggers are in the 5" range like the SOG Pentagon, CS Counter Tac (Aus8) and Counter Tac II(VG1) and are all very affordable. Moving away from the modern tacical look are the F-S based offerings, as well as old vintage daggers like the Kershaw 1007 Trooper. Once the blade goes under 5" I tend to refer to them as "boot knives" rather than daggers.
Thanks for the input, guys. The info is a real help. And if anyone has any additional suggestions, please post here.
I noticed a Tops one that looked promising. The name is escaping me...I'll look for it and be back.
That Ek is tempting to me too...
Applegate fairbairn is a good design, I have one from the 90's
The Gerber dagger is not what it used to be. The ones made today are a pretty pale shadow of what they used to be.
Yeah, that Ka-Bar EK is cool. I'd consider adding one to the stable, just because I'm a fan of Ka-Bar and EK.
If I was going to drop a big chunk of change on a dagger, the Case V42 would look cool on my coffee table.
Eickhorn Recon Force:
Shadowtech 8 inch dagger:
Joker CF01 (Joker is a Spanish brand that alsoroduce knives for a German company called Puma)
Aitor Botero
FKMD Marine dagger:
All of these are within your price range and NOT made in China. :):thumbup:
What's your intended use? Just a collection piece, or a carry piece? Some daggers are too large, or don't come with sheaths suitable for carry. I know of two
that I like in your price range, the Gerber Mark II for historical reasons $89.95 at blade HQ or for a carry piece I like the Benchmade SOCP for $89.25.
The SOCP is ambidextrous, has a well thought out and crafted sheath, it can be clipped many various places, and dummy corded so the sheath stays put when
the knife is drawn. Is has a ring, thumb jimping, jimping on the handle, and even a coating that has some traction to it for retention purposes. A good back up.
My interest is more as a carry piece rather than a collectable or show piece. Ideally, it will be capable of being more than just something pointy too. After all, as a knife, it would be nice it it could routinely cut things even though it likely will never be used for it's intended main purpose.
I've had my eye in the dagger from scrapyard, they come on the Busse exchange sometimes. Should be under a hundy, and good quality from what I've heard .
The Boker Plus Schanz integral dagger is one very tough/beefy dagger. And they can be found for under $150. I don't have one, but I've seen a lot of positive reviews.
This new Ka Bar EK is really tempting me as far as my Dagger search goes. I would love the Gerber Mark II but the serrations and steel type kills it for me, so sad cause they could really bring it back to basics. Does anyone have the new Ka Bar EK yet?
