If you random sample from cardboard you will simply be introducing a random uncertainty in your results. If you do this on the same type of cardboard (boxes from the same company) the deviation is so small it isn't significant.
-Cliff
Rediculous. Using boxes from the same company is in no way reducing the amount of variables introduced into the "making" of the corrugated nor will it reduce the percentage of variability of the data gleaned from its use in Cutting tests. Corrugated Manufacturers utilize Paper stock (for both Liners and Mediums) from many different sources with infinite amounts of Recycled material in each Slurry of material and thus each Roll of paper. Throughout each day and even within the same Lot (Box Run) Manufacturers will change Rolls, splice Rolls, change Weights of paper within an Order, etc. Higher amounts of Recycled material (and sources of this Recycled Paper) will have varying percentages of post (and some pre) consumer waste in each Roll, some as high as 50%. This material could include (but is not limited to) soft metals (such as Foil Gum wrappers, Aluminum Foil etc.) harder Metals such as Paper Clip chips or shavings, Dirt, Rocks and anything else that could have been introduced during the Recycle dropoff, pickup, compacting...... it is rediculous to believe that these materials would not effect cutting tests.
Another Variable is in all Corrugated is the adhesive (Starch), this changes from Batch to Batch and the amount used is adjusted throughout productions of each Order produced. The amount of dried Starch effects Rigidity and more causes a rigid liner to be stronger, the fibers more tightly woven together, making cutting much more difficult.
Another Variable in Corrugated are coatings, many Corrugated materials have coatings of various types to reduce moisture penetration (wax) or color enhancement. This effects the Coefficient of friction of anything touching the exterior or interior of the corrugated, perhaps allowing a blade to pass through the material with less resistance. Of course this varies throught an Order and widely varies throughout a day or week.
The variations contained in any single corrugated box (inch by inch) are significant but the variables from different corrugated materials (even from the same Manuf) are huge. Simply using Corrugated from one Company is like saying that all
Soda made by Pepsi should
taste the same...
cause their all made by Pepsi.. right?
I have not exhausted my ability to disprove your theory, but I have exhausted my patience. You may quote other theories from other Authors but I will stick with a simple
proven principle of analysis - perhaps published by Demming if I remember correctly - paraphrased - variables exist, you must find them, if you ignore them you do
NOT have true scientific results.
