Both the frame lock models the HD7 and 12 appear beefy but when you take into account the lock cut in the rear of the lock they end up being weaker than many of the liner locks in his line up if not all of the current models because I think he has beefed up the lock side on the entire line in recent years. The strongest knife Ernie sells is probably the CQC13 with the thicker lock, as opposed to the older models that had thinner ones as did many of the models pre-07 but in my opinion the best knife he offers at this writing for overall balance, and strength for the size of the knife is the mini A100 model. For such a small knife the lock appears beefy and overall the lock, hardware, and build all come together to form what I think is his best model but thats just my opinion.
Again, the frame locks are all looks. When you look at the sub .040 thickness lock cuts in the rear what you really have is a weak link there and it doesn't really matter how beefed up it may appear at the contact, the fact is that strength is not the frame lock's forte` its real claim to fame is the perceived higher reliability that is probably more than just perceived. It probably is going to be more reliable as a locking system in the hand compared to a liner lock that the scale blocks the hand from physically contacting. The trade off is a loss in some strength though because in order to make the thicker slab models work as easy as the liner locks he takes that great amount of material out at the rear. Personally I wish he did the lock cuts more like the Sebenza models that are left quite thick at these cuts by comparison and every little bit helps but it is what it is.
STR
STR
As a knifemaker do you prefer the cut out on the outside or the inside?
I know you weren't asking me, but Rick Hinderer says he puts the cut out on the outside precisely because of the type of failure seen in the Emerson pic above (paraphrasing of course).
STR
Was that yours by chance STR? I just picked up an HD-7. Any story on what kind of use the HD-7 was put to when it failed?
In my experience the contact pitch angle has much more to do with how the lock behaves under load than the lock cut in the rear does. Much more!
STR
It wasn't mine no. It is an HD7 though. I believe it happened while he was splitting some shavings of small logs to make a fire as I recall. As for the details though I cannot tell you that. He may have been using a baton but I really don't recall that. Truthfully if I ever suffer a lock defeat of a folder in use I hope that is the way it happens. Its not the most catastrophic defeat a lock can have let me tell you. No one was hurt when that lock folded. The lock did its job and secured the blade so by the way it defeated its evident the maker did his homework correctly for the design and you know the contact was correct at the correct angle or the lock would have gone the other way and a serious injury would have resulted. In my experience the contact pitch angle has much more to do with how the lock behaves under load than the lock cut in the rear does. Much more!
STR
Here is a good view of what I was referring to with the Mission knife which seen here is the MPF-3 that I own. Thats one tough knife there! http://www.bladeforums.com/forums/attachment.php?attachmentid=143638&d=1252807574
And here is the long cut down the middle from the outside I referred to. http://www.bladeforums.com/forums/attachment.php?attachmentid=143636&d=1252807496
STR
