Which gas forges have a probe hole for a thermocoupler?
Hi Guys,
I am looking to buy a new turn key gas forge 70 lbs or lighter. I want a thermocoupler and ceramic sheath to know the temperature, as I am a beginner and this knowledge will help me a lot.
I am also looking for it to have a choke, ignition switch and back door for a knife tip to stick out. I have been looking for about a month, and can't remember which maker or model had the probe hole.
I have heard that round works better for knives. I also heard some having trouble getting their diamondback forge to get up to a high enough temperature.
I have also read that the brick walls fall down in the chile forges.
If anyone knows of a gas forge with these features, please let me know. I am narrowing my search, I have yet to get in touch with Hoffman forges for a price on a custom forge.
I am interested in focusing on the knifemaking and knifesmithing techniques. I will eventually want to learn how to forge weld, but I feel that is well beyond what I should be practicing and learning.
Thanks,
Jon
You got the answers in your other thread asking about a light weight forge:
http://www.bladeforums.com/forums/showthread.php/1198348-Best-gas-forge-for-a-serious-home-hobbyist
You will have to drill the hole for the TC sheath yourself on almost any forge you buy, but that is easy. You have to add the TC and reading unit (PID) yourself, anyway. While the TC and readout are nice, they aren't really necessary.
Do some research and looking yourself to find what fits your budget and requirements. As has been mentioned in the other thread, you can't get everything you are asking for in one package. Either accept some limitations or change some of your requirements ( weight and cost being the most likely).
I still say you should get a Whisper Knifemaker and learn on it. Ad a sheath, PID,and TC if you want.
Thanks Stacy,
After doing research, I changed my list of wants, to up to 90 lbs. I will always have atleast one person to help down 6 steps to the hydraulic table at base of stairs. I have not asked or have got any answers to a question about thermocouplers, perhaps I don' t remember or you have me confused with another.
I am sorry to ask a question that you thought or might have been answered already.
Chile forges, will drill a .25" hole and say that is as big as they feel it should be.
As a total beginner, we do not have a propane barbecue, I want the manufacturer to do the port.
Also, now up to 90 lbs. that is the lightest of the Mankel forges.
I will check into the other forges, including hoffmann forges.
I will eventually get a secound forge to deal with other interests that are too big for the first forge.
As for the nc tool whisper forges, a person who has a lot of experience stopped using them and went to another brand.
He is an experienced blacksmith, just hard to talk to because I have hearing problems.
He told me to make sure I have a shade 3 ir protection when looking into the forge to take your work in and out.
He told me one of the problems with beginners is they do not let the metal heat up long enough to be all the way thru heated and not just on outer area of metal with inside still cold.
Thanks Stacy,
Jon
If placing a TC ( thermocouple ) permanently in a gas forge, you will need a TC sheath, or the TC won't last very long. That requires around a 3/4" hole in most cases. I am not aware of any manufacturers of forges for knife/blacksmith work that pre-install a TC sheath. This is something that the user does if he needs it. I really doubt most new users need a TC in their forge to start with, as the only place it is has any real use is if the forge is built with a blown burner and PID control. The blade and the TC are also unlikely to be the same temperature as well as the hot spot issues with most commercial forges. Again, adding PID control is something the user does on the type of forges we are discussing. The stickies and many past threads have good discussions and information for installing PID control. Auberins has complete TC and controller kits with all the parts needed, and the installation is so simple a cave man can do it. Once a TC and the PID are installed it can be used to monitor the chamber temperature. Converting the unit to PID control requires adding an LP gas solenoid to the propane line at the burner. The stickies explain it all.
As to the NC whisper forges, their biggest advantage is their portability and ease of use. Many other commercial forges are better at this or that, but the NC knifemaker models are really easy to move around. The side door on the lowboy is great if you do blacksmithing and ornamental forging, too. Their knifemaker model is a good venturi forge for the money.
Commercial forges will be built in ways that allow shipping and manufacturing ease...not for the features a small group of folks like knifemakers desire. They will be more "universal" and certainly lean toward ornamental work in iron than knife work in steel.
The main reason people build their own forges is to have all the features they want in a forge. Round chamber, chamber size, blown burner, burner placement and alignment, PID control, ports, and other features....all the way you want them.
If a Mankel Knifemaker fits your budget and weight requirements, it is a great choice. They allow use in several configurations with merely the moving around of some firebricks. However, they are not what I would consider portable for daily use. It would be very easy to add the TC to a Mankel, as the firebrick is simple to make a hole through.
Just an FYI, but a full size forge can take several hours to cool down enough to move. Additionally, firebrick and cast refractory does not move about well.
http://mankelforge.com/index.html
Food for thought - If considering doing your own HT, then getting a general use forge for forging and a HT oven for doing the HT is far better. If your budget allows it, a Mankel round belly knifemaker's forge and a Paragon KM24 or Evenheat KO22.5 will make a great combination for most any requirement you have. A forge is for forging, and is a basic HT device at best. It is only as accurate as the experience of the user in HT....and limited to simple carbon steels. An oven is a dedicated HT device and can do spot-on HT for any steel a knifemaker wants to use by merely punching in the numbers. In the final decision, you will have to consider your knifemaking now and in the future when making the purchase.
Final comment - If you are just looking to get your feet wet and start learning how to forge.....and will be carrying everything in and out of the house.... then maybe a smaller forge, like the Atlas is what you need at this point. Add a HT oven and a larger forge as your skills grow. The Atlas will always have a place in your shop for smaller work and portable forging projects years later when you might live in a different home with a dedicated shop.
Thank you so much,
You really are filled with knowledge.
I was starting to wonder exactly what you have suggested, start with a mini-atlas. Then when I gain experience I will have a better idea in the direction I am most drawn to.
Dave from chile forge mentioned that they drill a 1/4" hole and would not " feel comfortable" making it bigger, like 3/4" for the ceramic sheath.
He said there is a company that makes a alloy that is 1/4" and does not need a sheath.
He sent me the link and said that another co sells the thermometer to hookup to the alloy probe wires.
Thanks again,
Looking forward to making my first knife.
Be well,
Jon
Yes, you can use a 1/4" monel clad TC. If you do, do not leave it in the forge when doing any forging...just for HT. It will not take continuous high temperature. The ceramic sheath and 1/8" wire TC is a more robust setup.
But when you do as Stacy mentioned above, it's just as easy to stick it in only when you want to check. I've got a TC hooked up to a multimeter sitting in a drawer that works fine the couple times a year that I need it. Just stick it in next to the metal.
