Which is better the Cold Steel Kobun or the Columbia Rive ultima?
the cold steel kobun is a good little knife,(bootknife)with a thin handle
If you want a Kobun you might hurry. They're not listed on the CS website anymore so I assume that that means they've been discontinued.
As much as some people dislike Cold Steel, they are still a step up from CRKT.
I have a Oyabun (nine inch version of the Kobun), and while the tanto really isn't the most useful blade profile, it does seem sturdy enough. The blade took a slight bend after some prying and the Kraton handle developed a little play after batoning, but other than that it's doing pretty well.
Really, if you want a knife you'll appreciate in use, something more traditional would probably do better. I've been considering the Benchmade 158 (CSK II) for a while now, it's made of 1095 and has a Santoprine handle (very similar to Kraton). In theory it should be one darn tough knife. If that's what you're looking for that's what I recommend. If you need something more stainless the Cold Steel should be ok. (or you could take a look at the Benchmade 10502)
BM158 CSK II
http://www.knifeworks.com/index.asp?PageAction=VIEWPROD&ProdID=11203
BM 10502 Rant bowie
http://www.knifeworks.com/index.asp?PageAction=VIEWPROD&ProdID=10516
I have an older one made in Japan from AUS-8 steel. I like it a lot. I don't know about newer ones made elsewhere from other types of steel.
I've got the Kobun, it can take a very sharp edge. I think the Ultima would be stronger though if the Ultima has a full tang (the Kobun doesn't from memory). But then again, the Kobun was designed as primarily a self defence knife (Cold Steel calls it their boot knife) with a thin profile designed for easier concealment
I would rather have a Mora in my hand for utilitarian purposes than either one of these knives. My only experience with Columbia River Knife & Tool has been very good (I got the very large version of the Crawford-Kasper folder with a black-coated blade for twenty bucks and it has served me well as a "beater"), but the quality of their knives as of late seems to be suffering.
The newer version of the Kobun are not designed for very serious use, being designed without a full tang in the handle. 4116 Krupp stainless is decent stuff for being so gosh-darn cheap, but I'd rather have VG-10 or S30V any day, and the Moras really perform for costing a ten-spot.
I'd skip both of these and buy a Spyderco Aqua Salt, cause I'm a Golden Kinda Guy. ;)
God bless.
KATN,
Wade
