- Oct 23, 2010
I buy two of the same knives so that I can use one hard and have a back-up. I usually pick the one that has the most problems to use hard, and I put up the one that's in the best condition. So help me.
The first manix has slight blade play, but not really enough to notice unless you try. The lockup is early on it and the action is smooth as butter.
The second has no blade play at all, but the ball bearing engages almost all the way into the blade. Also the ball bearing sticks a little when you try to disengage the lock.
So which one do I use, and which do I put up?
