Which spec ops to fit skinny ASH-1?
Looking into getting a spec ops combat master for my Skinny ASH. Was wondering if it would even work with this knife. I've seen alot of Busses in them but not a Skinny Ash when I searched the forum. If anyone has used one let me know what you think and if you had to do any mods to make it work good. Also would I need the long or short. I figured the short.
John
If you go to spec-ops website you will see they have a combat master sheath for smaller knives as-well, maybe the ash is too wide for it though?
My ASH-1 LE fits in a smaller Combat Master with the kydex liner widened a little in the oven. If I recall correctly it would not fit without widening, and the liner only just fits back in the sheath. I also removed the liner's fixing screw. The liner is a tight enough fit (after widening) in the sheath that the screw is not needed.
I even have an HHFSH in a Combat Master!
The inserts in Spec-ops sheaths respond really well to a heat gun. I tape off the knife to add "girth" and then heat gun the insert to shape if they are tight. My NMSFNO wouldnt fit at all and after a few minutes with the heat gun, it fits like they were made for each other.
