If both were taken to the 60-61HRC I understand the XHP is taken to, then the XHP would be tougher, however the AUS8 is run at 57-58HRC which means its heat treatment favoured toughness over hardness. The BD1 is, I understand, also run at 57-58HRC at which point it is tougher than the AUS8 at the same hardness.
XHP is probably tougher, but we'll have to wait and see some comparisons.
im sure you are already aware of that judging from your tone but just in case you need something more specific beyond the literal meaning of "toughness".
At the same hardness XHP should have an advantage in transverse toughness. I have no idea whatsoever about longitudinal toughness or how XHP at 61 would compare to AUS8 at 57.
