white Kydex
Has anyone got any white or "ivory" kydex?Does it even exist? I have a special project and want to use the kydex for the sheath. If you have some can I buy 1 -12inx12in square?
Thanks
Hi Was...
White is available in Kydex anyway...
Not to sure who would have it,, but I know it is made..
You might want to check some local plastic supply houses though...
Let us know what you find out,, and good luck..
ttyle Eric...
Eric E. Noeldechen
On/Scene Tactical
http://www.mnsi.net/~nbtnoel
The most tried method, and generally successful method, is to call the manufacturer and explain exactly what you need. State your quantity. Then proceed to beg for a sample to proto with. Kleerdex is usually good about coming through. Also, Blade-Tech may be able to get you white concealex. One of the overlay patterns is (or was) on a white synthetic.
www.kydex.com www.blade-tech.com
>)-RadarMan-(<
When you argue with a fool, that makes two -- Vermont Proverb
