I can`t wait; I`ll review `em both when they land.
"Composite Shear – Glass Fibre OAL 10” Length of cut 5” Forged from high carbon tool steel Specially designed to cut glass fibre Xylan coating aids cutting performance Specially ground and set blades contribute to a ten-fold improvement in cutting life over standard shears Serrated blade holds loose fibres to improve cutting performance Can be used with pre-peg ''wet'' processes Shear also available with rounded points in order to avoid the tips snagging the fibres of loose weaves often associated with these materials Composite Shear – Carbon Fibre OAL 10” Length of cut 5” Forged from high carbon tool steel Specially designed to cut carbon fibre Xylan coating aids cutting performance Specially ground and set blades contribute to a ten-fold improvement in cutting life over standard shears Serrated blade holds loose fibres to improve cutting performance Can be used with pre-peg ''wet'' processes Shear also available with rounded points in order to avoid the tips snagging the fibres of loose weaves often associated with these materials"
William Whiteley & Sons 127 mm Electricians Scissors
William Whiteley & Sons 10 in Heavy Duty Shears
