samwinthrop
- May 26, 2022
Who would you recommend for a DLC coating on a Ti framelock handle?
Thanks!
Thanks!
Some things just need to be blackWhy would anyone want to hide Ti. It won't rust and won't corrode during normal knife use.
Disassembly is no issue. The lock face with be re-carbidized after coating as not to slip. The detent ball should be fine but the detent hole could always be opened up a bit if needed to make up for the coating. I agree that the biggest challenge is getting someone to do a one-off order. Maybe I'll just DLC all my things?You would need to disassemble the knife. And I don't know what it would do to anything like a detent ball. If the titanium lock bar has a steel insert at the lock face, I don't know what that would do either.
That being said, DLC coating is a vacuum vapor disposition process. (Means it takes lots of expensive equipment.) I think you'd have to look up one of the big processors who performs that type of coating process. I don't know if they would take a one-off order. No little guys exist as far as I know.
Expert DLC Coating Service & Technology
Enhance component life with our expert DLC coating service. We combine advanced technology with global reach for all your coating needs.www.ionbond.com
With all of those heat cycles you have to wounder what the hardness of the fuselage is.Why would anyone want to hide Ti. It won't rust and won't corrode during normal knife use.
An aluminum SR-71 would melt like a Popsicle.
