- Nov 17, 1998
Which company makes the best, most durable folding saws? Thanks.
Comparing common hardware store blades with Silky blades is apples and oranges. TOTALLY different classes.![]()
That is indeed what the internet says... but how about real world side by side tests ?
In my expreience the difference is marginal !
Yes, they are "different classes." If we were limited to comparing saws within a single class, then the Silky might be the winner. Since we're not limited in this fashion, the question is "Who makes the Best Folding Saw," and so, this comparison is perfectly reasonable.
Break a Silky saw, and it's much more likely to happen than with the Dustrude, because it's only supported at one end, while the Dustrude blade is tensioned between two supports, and if you're not carrying a spare, you're SOL. Any Home Depot has blades that will fit the Dustrude and so will many hardware stores in small towns. And the carrier for the Dustrude has a pocket for a spare blade.
The full 21" of the Dustrude blade is available for cutting wood. Making it much more efficient than a bow saw (still in "another class") which has a triangular shape and therefore you lose the blade length "at the small end" when you get into processing bigger pieces of wood.
The longest Silky that I've ever seen anyone carry is the 210mm (8-1/4"), a little less than 1/3 the length of the Dustrude. They make longer blades and if you're car camping, they might be a choice, but the longest that I've found is the 420mm (16-1/2"), still 5-1/2" shorter than the Dustrude.
The Silky was intended for gardening and maintaining trees where clean cuts are important so that the plants heal faster. I'd bet, since the OP posted in Outdoor Gear, Survival Equipment & More, I'd bet that he's more interested in processing wood for fires, than gardening or trimming a tree. There, a clean cut is not important, speed and efficiency is.
I used to use a Silky. Now I use a Dustrude. I'll never go back.
I've never broken a pull-cutting blade, personally.
And I find my Silky outperforms my frame saws in the speed and efficiency department, personally.
The fact that it yields such a clean cut is more of a bonus.
But we all use our tools a little differently and have our own preferences. Heck, I honestly don't use a saw at all most times I'm out--I just use a machete for most of my cutting tasks.
