who sells the ZT0300
I did some searches on the internet and only found one place selling the zt0300, that was tad gear. I would like to do some price shopping.
Does anyone know any other shops selling the zt0300.
Thanks
I'm kinda thinking it was commissioned by Tad Gear,......as it doesn't show up on the regular ZT link from the Kershaw link.
...so it's probably an exclusive. Not sure however..........
I do like the satin blade and extra apparent strength in the grind,.......but personally would prefer it in a black G10 scale version for civilian use.
New Grapham has it way less expensive. But TAD Gear has bigger choice.
Thanks, Vassili.
Greetings. Both Joe and Vassili are correct. The ZT0300 is a TAD Gear exclusive. It's available in OD green, or brown. The CE and DW knives have a longer false edge along the spine of the blade. The DW also comes with a desert camo handle. TAD's 0300 non CE or DW knives are the same as you can find at the pharmacy, except TAD is sold out, while NGK has stock, and are priced a lot less as Vassili noted above.
...and NG starts selling it year after TAD Gear, so I have mine for full price on BAKCA show...
BTW - TAD continue to list it as 4.25" while actual blade length is 3.75" for ZT 300.
Also ZT-200 listed as 4.25" while it is 4" and not CPM 154CM - which is noncence it is actually 154CM. I can understand if they name steel as Crucible 154 CM, but CPM 154CM is misleading because there is different steel CPM 154.
Thanks, Vassili.
New Graham has a zt0302 in stock.
The description says that the blade is 4.25 in.
Is the blade 4.25 or 3.75 on the 300 series?
I've seen a few on ebay.Got one with the tiger stripes & coyote brown handle for $225
It's 4.25 in.
Can you verify it and better post picture near ruler, please? I start thinking that I got shorter Version somehow...
Mine are ZT200 - 4"
ZT302 - 3 3/4"
Here it is clear that ZT20 has longer blade:
Here it is with Cyclone (3 3/4")
I just checked NG and they list 4.25" also. I think this came from Kershaw Marketing, I guess they should fix it - it is after all misleading customers...
...Or did I get shorter Version somehow?
I will post it tomorrow picture of mine near ruler.
Thanks, Vassili.
