Why 3 heats to normalize?
If I have some stock removal blades of 1084, is it necessary to heat and cool the steel a full 3 times each to do a normalization, or could I get away with just heating it once to 1600, letting it cool to black and then getting on with my hardening process?
I'm doing this in a forge, so I feel the more times I heat these things, the more room there is for error and it's not like an oven where I can just stick 5 blades in all at one time...so it's a little trickier.
The normalization causes grain growth, so grain refinement is recommended to get better microstructures. The two grain refinement heats are below the normalizing temp.
in a forge, try bright red, then dull red x2. I don’t do this in a forge so someone might give you better info on colors.
So with stock removal, could I just do a couple lower temp grain refinement heats and skip the higher temp?
Nevermind... I think I know the answer to this. I'd wamt to do the normalizing heat first to get all the elements of the steel uniform and then refine from there... Just a PITA doing it in a forge.
Where did you get the steel from? If AKS, no normalizing required. If NJSB, normalizing required.
That surprises me, I prefer normalizing and grain refining in a forge. Fast, you don’t have to wait for the kiln to cool.
When I do the normalize and grain refinement, does it need to cool completely to room temp each time, or just to black and them back in the heat?
