I'm curious what you are doing with serrations that would demonstrate any advantage to grinding on one side or the other. Even chisel ground plain edges really make only minimal difference in use unless you are doing some really precise work.
Opinions vary, I suppose. That said, I use such a wide variety of grips and positions, that I can generally make any given knife work if it is properly sharp.
Partially wrong. It makes no difference when you are cutting "stuff". I have used and currently own a lot of serrated knives. The chisel effect doesn't stand put because it is a very small area of the cutting edge that is ground that way. It's not the knife, rather how you use it.I don't like serrations, but if I did I'd want them to be cut on the right side of the blade instead of on the left. I just imagine they would work better for right handed users.
Is my theory wrong, or are serrations very left hand friendly?
Same hereI've never noticed a bit of difference. Since serrations are really best at slicing, I have never noticed it matters.
Serrated knives are not saws.I like to have a knife not a saw...
I have read that they photograph better on the presentation side of the blade. Marketing I guess.
Tom
Because you want to take a picture of the non clip side. It's all for looks.
In culinary A lefty or righty it does/can make a difference in processing Onions tomatoes etc if you are the kind of chef/cook that prefers using them.
With your Field,Camp etc.. The serrations are put on the front side for your viewing pleasure.
Well, chisel grinds do affect the angle of approach that you can use on each side. If you have two 30° edges, one single bevel and another double bevel, the double bevel will be able to cut at any angle between 15° and 90° on both sides. The single bevel will be able to cut at any angle between 0° and 90° on one side and between 30° and 90° on the other.
