Ok thank you very much for this information and it's not that it can't be done it is that it is just not efficient to do so.
It can be, but not on a commercial production scale. H-1 is not conventionally heat-treated. It is hardened by working it. It is cold rolled to a specific thickness and hardness, then cut into blanks. Grinding will further harden the steel. Flat grinding commercially is done one side at a time, so when the time comes to grind the other side, it is a lot harder than doing the first side. This leads to excessive tool wear and can lead to overheating of the steel. Hollow grinding is done on both side of the blade at the same time, so the work hardening will be even and so will the tool wear.
H-1 can be flat ground by alternating sides and cooling frequently, but that is too labor intensive to be cost effective for mass production.
Its not commercially viable on a mass scale, just send your H1 knives to Tom Krein if you want a regrind!
