Fred.Rowe
- May 2, 2004
I enjoy heat treating steel. The whole process of; heating the metal, watching the colors change as the steel changes temperature, the quench, the hole thing. I started out using a torch, edge quenching. Then I read about heating the hole blade, quenching that, and then using my torch on the spine.
Then about two years into this, knife making thing, I tried, CLAY. Now there is a ton of "mystic" in the knife world, but when it comes to clay, it has more than it's share. I used my usual scientific approach, I purchased 100 lb bag and started using it.
So now, four years later, I have a process that I use that gives me the results I am looking for; hard edge, tough-ductile spine, controlled temper line.
I can control the rate, at which, different areas, of the blade cool, after quench. A friend came by the shop and watched me harden a blade. When I was done , he asked; why did I heat the spine of the blade first? I answered;" you want the spine to be at non magnetic, so when you quench the blade, the spine will not harden because of the clay, but it will result in
a spine that is very tough and yet ductile"
Do you think my reasoning is sound? Give me your approach to clay. Fred
