Why didn't anyone tell me about the Kershaw Storm before now?
I just picked up a Kershaw Storm II from an online dealer for $28. If there's a better knife for that price, I'd love to see it.
A Ken Onion design, with his typical flowing lines, recurve blade, and reducing-diameter hole patterns. The handles are 1/16" stainless steel slabs, with the front handle having two inlays of a black grippy material, and two sets of "Onion hole" patterns. That back slab is smooth, with a frame lock and a wide pocket clip (which also has the Onion hole pattern.) The blade is a hollow-ground 3.5" of Sandvic 13C26 stainless steel (whatever that is), and a gorgeous recurve shape. (There is also a 3" version for those looking for a smaller blade.) The blade and handle finish appears to be some sort of bead blast, which gives it a frosted look. It has dual thumb studs, which seem too small at first, but prove to be fairly effective. There is also a small flipper tab to flip the blade open, but my knife is too tight right now to really use this feature. Just as well, because I prefer to open the blade with the thumb studs anyway. The opening action is very smooth, even though the amount of resistance is more than you'd feel in say, an Axis lock. The flipper tab acts as a finger guard when the blade is open. Naturally, for this price this is a manual-only knife - no Speed Safe action here.
The whole package is only 5/16" thick (without the clip) but weighs almost 6 ounces. It feels very solid. The fit and finish are better than you would expect for the price. The blade locks up solidly, with no side-to-side or up-and-down blade play. The ball detent is excellent, providing what I think is the perfect amount of resistance to hold the blade closed. The blade is perfectly centered when closed. There are mild traction grooves on the handle spine and on the frame lock. They (along with the handle shape) provide a very secure grip. The one thing I didn't like was the handle inserts. They have the feel of rough (maybe 100 grit) sandpaper. They could tone this down a bit without affecting the grip IMO.
The knife is an open back design, with only two black (plastic?) standoffs and a steel stop pin. Very open and easy to clean.
The knife came with a fairly average edge, but a few strokes on the Sharpmaker, followed by some light stropping brought the edge to shaving sharp. I've only cut a few arm hairs, some paper, and the cardboard box the knife shipped in, so I have no idea how long this steel will hold an edge.
The pocket clip fits with the style of the knife, and is unobtrusive when gripping the handle. The clip grips my pants pocket tightly, but still slips easily in and out of my pocket when I need it to.
About the only thing I'd change is to use a less grippy material for the handle inserts.
If you're looking for a thin, strong, sturdy, frame lock with a typical gorgeous Ken Onion design, then the Storm line is a great choice. It would also be a great gift to give your friends who might be teetering on the edge of knife disease. :) For $28 you can't go wrong.
Oh yeah - it's made in the USA as well!
Hey, YOU'RE the Senator..;...we were waiting to hear from YOU!!! ;) :D
Great review also. After reading about this knife so much I may have to get a StormII to play with. Especially at that price!
I'm not a fan of recurve blades but Vapors seem to be essentially the same thing, except that they have "normal" blades. Can't wait to recieve mine, it's on the way and due sometime around x-mas :D
I have one and you all are soooo correct. Great bang for the buck. I haven't really used it yet to see how the edge holds up. I'm looking forward to testing mine out.
A fine slim profile and a meaty handle and blade.
I like it!
Tom
Edge holding is better than 440-A and not as good as ats-34 . Check out the flat ground Storms . Wicked sweeping plunges for a flat grind !
Are you the same Ken Onion who designed those knives ? Please make the thumbstud slightly less pointy and/or make it bigger (in diameter) next time you design a knife :) Perhaps move it a tiny bit further (toward the tip of the blade) too, 0.5-1 milimeter or so, i think it would make the one hand opening slightly easier.
I love the Vapor but that thumbstud can be PITA, i've figured out how to open it with one hand and no pain but it's the only folder i own that i have to open with the top side of my fingernail (once i figured out this "technique" of sliding my thumb as a wedge under the thumbstud it's fine and dandy, but odd nevertheless).
faramir, try filing down a pointy thumbstud with a ceramic sharpener. It may soften the shape enough to make it much more comfortable. I've done it with my Sebenzas.
Esav, i'm not entirely sure whether it's the "serrations" (concentric rings the thumbstud appears to be composed of) or the point itself that causes the sore thumb, i have a feeling it might be the combination of both (and i cannot possibly imagine how those "rings" make stud any less slippery if wet, or whatever their purpose is).
Either way, i'll do that as a last resort if i don't get accustomed to opening the knife with my thumb nail because it's the black version and i'd hate to ruin the black finish :grumpy: This nail technique is quite reliable and looks fancy, i only need to get the blade out ~1 cm (0.4") or so and then open it entirely using the thumb as i normally would.
Perhaps trying different angles when leveraging the thumb stud may produce a technique that is less abrasive to the user?
I have found that trying to push the blade out in a sort-of 90 degree direction from the handle makes opening the Onion design very difficult.
If you're not doing it this way, try pushing the thumb stud toward about 10:00, slightly outward but mainly forward... It really makes it easy. :cool:
