Good thoughts, everyone.
I think the last thing I stabbed was cardboard while starting a cut on a particularly large TV cardboard box. I don't often "stab" stuff.
But what I like a guard for is to make sure that if I point the knife upward (to make it "safe"), or accidentally lose my attention for any reason (wife yelling, fire alarm goes off, cat grabs my leg), that my finger doesn't accidentally end up where it shouldn't. When I don't have anywhere to index the location of my hand, it's easy to have it shift around.
For clarity:
What I mean by a "guard" doesn't necessary involve a Rambo-esque brass thing. I just mean something that keeps your hand from slipping forward.
Some posters have brought up some of these methods:
-the deep finger choil (a la small Spyderco Dodo, Lava, etc.)
- recessed handle groove (a la Yojimbo)
- the dropped edge (a la kitchen knife).
These aren't guards per se, but they WILL keep your fingers off the edge in the case of an accident.
To be honest, the dropped edge of a kitchen knife is a perfect guard. Your hand and fingers are kept totally and completely away from the edge. You can butt up against the back of the blade (the kick?) and you'll never, ever, slide onto the edge.
Do these types of design elements still get in the way when whittling?
Puukkoman,
Ahhh...thank you. NOW I understand -- so, the problem is that the edge needs to be flush with the cutting surface. So a Rambo-esque guard would stick out and be in the substance you're cutting. However, with a "normal" knife (take a small kitchen utility, for example), your knuckles would hit the cutting board before the edge would be flat , wouldn't it?
So the problem isn't solved by a lack of a guard, but rather a "negative included angle", or a dropped edge?
Thanks!
-j
