why do chefs/butchers use softer steels?
I've noticed only butchers and chefs use softer steels. Why is that?
Does a blade that can be steeled able to last longer than a harder rockwell knife that can only be touched on a stone?
In what conditions does it benefits of using a lower rockwell knife?
Butchers some times like the Forshner knives which are a little softer, it makes them easy to touch up when they are cutting meat all day.
I don't see this at all with chefs here in the USA? Chef's want an edge that is going to hold well under hard use during the days work.
My boss has a son that is a chef in training and he has task specific knives. If he has a risk of hitting bone he will use a softer steel, otherwise he will use a steel run a little harder.
Again, no personal experience here, only what I have heard.
Because places that process meat don't buy high dollar knives for their employees.
Health reasons mostly.
The perception that a harder steel is not used is though false. Case in point Nitrobe-77 was developed for the food processing industry and can reach hrc of 63. It was designed not to chip out as chipping of steel in the food industry is a no-go. This is stated in most laws and ISO documents with regards to food processing.
This is the same reason why higher carbide steels and steels that could chip easily at higher HRC are normally not used in the medical profession.
So to resolve the risk of chipping taking place wanting a steel that is easy to sharpen and cost effective the option of a softer steel is chosen.
In my experience there is a BIG difference in 12c27 at hrc of 55 , normally in butcher knives etc compared to 12c27 at hrc of 61 with custom heat treat.
My two cents.
Economics and the point of diminishing returns. The best equipment available is almost always directed more at niche enthusiasts than professionals. Dexter Russell may not compare to high end cutlery, but they make perfectly respectable knives that are inexpensive and easy to buy in bulk and replace when they break/get swiped/are sharpened out. A really nice kitchen knife might last 3-4 times longer than a Dexter Russell, but it will likely cost 5-6 times as much.
I know a bit about this. It isn't chipping of the blade. Honestly, how often does that happen - especially to a professional who knows every single cut? It also isn't cost effectiveness, since I've seen butchers that will spend $300 on a knife that is 57hrc. What it comes down to is the razor edge that is needed to cut meat, and the process of cutting the meat. A regular knife that we all use at home is harder because we use it, wash it, and put it away. Rarely do we use the honing steel, thus they make the knife harder to require less maintenance at home because that's what the major market desires - a knife that is easy to take care of and holds an edge. Most consumers have no clue how to use a steel, and most also have no clue that it DOESN'T sharpen the knife. It just straightens the edge. The butcher, on the other hand, is constantly using his steel. The reason is due to that soft blade steel, but it goes deeper than that. As stated before, the steel only straightens the edge on a normal hard kitchen knife, but on the much softer butcher knife it actually will do minor sharpening as well. This is the key. If the butcher uses his steel properly, he will always have a razor sharp knife that he needs to do his work. Certainly he could buy a harder knife and just use a ceramic steel, but keep in mind that this would remove quite a bit of material; plus the constant cleaning of the ceramic, risk of breaking the rod, etc. The honing steel is the best method. It removes so little that the knife lasts forever while always being maintained. This is why butchers use softer knives, and it's also why they constantly are wearing a honing steel and use it every 4-6 cuts. Some people would believe this to be tedious, but honestly it becomes second nature to the butcher and his knives are always razor sharp.
I think it has more to do with blade geo and heat treat than the steels specific hardness.
I have several knives that are used on a daily basis by professional butchers and they say that they can go days, weeks even, before needing any sharpening, stropping, or steeling. Most of them are young guys who work right alongside older guys who use softer knives and steel them as needed. Traditions and old habits can be hard to break.
