Why do dissimilar metals weld together when heated very hot. Now thats is a good subject. Really I know they do weld together when heated up the same temp but scientifically why do they do it. Damascus is made this way. Is it that because the metal is molten on the surface and when squeezed together at this high temp they bond but really what is happening?
First let me try to restate your questions.
1. (scientifically) Why do metals weld together when heated?
2. Is it because the metals are molten on the surface?
Short answers:
1. heating aids diffusion
2. no, bonding does not require melting
Long answer:
Metals can be bonded by solid-solid, liquid-solid, or liquid-liquid diffusion.
Some examples of bonding by solid-solid diffusion are Diffusion Brazing, Pressure Gas Welding, Resistance Welding, Flash Welding, High Frequency Resistance, Percussion Welding, Projection Welding, Resistance-Seam Welding, Resistance-Spot Welding, Upset Welding, Diffusion Welding, Explosion Welding, Forge Welding, Friction Welding, Hot Pressure Welding, Roll Welding, Ultrasonic Welding, and Induction Welding.
Some examples of bonding by liquid-liquid diffusion are Carbon Arc, Flux Cored Arc, Gas Metal Arc, Gas Tungsten Arc, Plasma Arc, Shielded Metal Arc, Stud Arc, Submerged Arc, Oxyfuel Gas Welding, Oxyacetylene Welding, Oxyhydrogen Welding, Electron Beam Welding, Electroslag Welding, Laser Beam Welding, and Thermit Welding.
Some examples of bonding by liquid-solid diffusion are Dip Brazing, Furnace Brazing, Induction Brazing, Infrared Brazing, Resistance Brazing, Torch Brazing, Dip Soldering, Furnace Soldering, Induction Soldering, Infrared Soldering, Iron Soldering, Resistance Soldering, Torch Soldering, and Wave Soldering.
Now to understand diffusion.
The diffusion process is the transport of mass atom movement through the material.
Diffusion of atoms is a thermodynamic process where temperature and diffusibility of the material are considerable parameters. In general, the diffusion rate, in term of diffusion coefficient D, is defined as D = Do exp(-Q/RT) , where Do is the frequency factor depending on the material(s) and the oscillation frequency of the diffusing atom. Q is the activation energy, R is the gas constant and T is the temperature in kelvins.
The interface contact can be optimized by a treatment of the surface to be bonded through a number of processes, such as mechanical machining and polishing, etching, cleaning, coating, and material creeping under high temperature and loading. Creep mechanism allows a material flow to produce full intimate contact at the joint interface.
Therefore, materials compatability, surface treatment, temperature and in the case of solid-solid fit-up and loading are the important factors of the diffusion process.
If you are still unclear on any of this let me know and I will give it another go.
