- Nov 17, 1999
Hello folks,
I'm plotting to make an attempt at making a framelock folder this summer ( so stay tuned), I have acces to some hi-tech precision machinery, and the guy who operates them daily proposed to make a few folder this summer.
I was working on plans and diagrams and so on, and it struck me that the liner or lock side needs a much smaller washer. Then I went to check on folder that have huge washers, like a MT LCC, and it struck me that the bigger the washers, the higher precision required, but also the more stable your knife feels.
Then I tried to figure out why a washer needs to be round. I checked, and on ALL my folders, the washers don't move at all, the blade slides between the washers. theoretically, they could be square and have the same effect. Of the BM 750 framelock, I even suspect that the washers are GLUED to the scales. Then it hit me.. if this is so, then why don't you make a washer that is almost as wide as the entire blade, with cutouts for the lock? It would greatly increase stability of the folder blade.
Are there some framelock folder makers out there that are willing to give this a test and potentially ruine a bit of teflon ? Insted of making round washersm try and make a washer that's lot's larger in surface, much larger blade contact, with a cutout for the framelock? I think you can keep it from rotating if you let it extend to the blade stop, so it's jammed.
or am i just missing something here?
It's all theory so far, but I like to study my theory before actually doing it in real life
greetz and take care, Bart.
