- Feb 24, 2000
Lately there have been several posts about metal bandsaws. I have two metal cutting bandsaws, but rarely use them. One is a Jet 64" model, the other is a Wilton Tradesman that has a transmission and can be used as a metal bandsaw and also a wood bandsaw. I use a wood bandsaw a lot, but rarely see a need for a metal bandsaw.
It seems that knifemakers use the metal bandsaw to profile blades. I read where they also use angle grinders.
I think there is a lot easier way.
I will be talking about the stock removal method.
I learned to make knives from Bob Loveless' book "How to make knives" I still think it is the best how to do book ever published. I use blaze 36 grit belts to taper tangs on a flat platen like Bob shows in his book. 3M belts are also good, I just like the Norton Blaze belts better. When the 36 grit belts start to loose their cut, I use them to grind the bevels in blades. Some say the 36 grit belts leave deep scratches that are hard to get out, but if the belt is worn down from tapering tangs, that's not the case. The 36 grit scratches easily come out with a 60 grit belt.
When the 36 grit belt starts to loose it's cut on the bevels, it would normally be thrown away.
I use these worn 36 girt belts on a hard 8" serrated contact wheel to profile blades. It goes fast and with the 8" contact wheel I can get in tight corners where a bandsaw can't get.
I timed how fast this was and profiled 3 blades like the one in the picture above in 7 minutes 30 seconds. The blades are 9" in overall length.
I am using belts that are no good for anything else.
To cut the knife steel to length I use a chop saw. These run from $200.00-$400.00. The abrasive wheel they use costs around $6.00. To cut knife steel to length a chop saw is much faster than a metal bandsaw.
So, if you wish to use a metal bandsaw, that's OK with me, I just thought I would share how I do it.
