Me too. The large Voyager is a big knife. Nice thick Phosphor washers like on an Adamas would be perfect. My question is how long will those nylon washers last under EDC conditions. They are rice paper thin. Friction, dust, and or dirt/debris will be getting in there, and wearing them down. I'm guessing over time they will wear down, and create side to side play. Sure you could snug down the pivot screw, but now you're tightening down for the missing tolerance of the nylon washer. If and when that happens I'll just get some washers from that knife part supply place, and rebuild it with some nice thick ones.If I had to guess I’d say it’s for initial smoothness. Also with the teflon being compressible it allows for less strict tolerance. If for nothing else then for simplicity I'd prefer a single washer.
That's the info I was looking for. Thanks brother.
cold steel back when they ran this forum said it was to reduce warranty claims, due to folks not occasionally oiling the washer. over time the washer would polish itself with enough oiling and kept clean....so I doubt that's the reason. what the old cold steel rep said makes sense to me. it's to save money but on the backend, not the front end......Necro bumping this because I wanted to share my opinion...regardless of how mistaken I might be lol.
As a matter of fact I might be doing it wrong but to me removing the Teflon doesn't mess up much with tolerances. It only makes the knife less smooth at first but if I then mirror polish the liners and the pivot area on the blade the knife works the same again if not better than stock.
In my opinion it's there to save the cost of polishing everything at the factory. Personally I don't mind the cost saving, and I enjoy doing this ritual with all of my new Cs knives. I've just done it to my new Rajah III and it's smooth as butter, with no play nor any tolerance problem by the looks of it.
Anybody else thinking the same?
