Mike, there are two aspects to this chisel grind business.
1) Many Emerson knives have a chisel grind as a primary bevel. They are completely flat on the right side, and saber ground on the left. A knife ground like this will tend to curve off to the flat side when cutting.
For utility, a chisel grind should be on the strong side, like some Japanese chef's knives, which are ground on the
right. They can lay the flat (left) side aginst a chunk of fish, and cutting downward, slice off precise, thin slices.
2) But even knives with a v-grind can have a
secondary bevel only ground on one side. These too will tend, very slightly, to curve off to the unground side. You can find a chisel ground secondary bevel on most serrated blades.
The correction for this can take time to reprofile, or simply live with for a while, and every time you do sharpen, sharpen it as if it's a v-ground secondary bevel, and eventually, it will be.
