malazo
There is no set in stone chronological line. I have been giving folks my experience with the products to give them an idea of the Generations.
Let's see if we can get this tied down a little.
'98 through mid '99 were First Generation Commanders
First generation Commanders are pretty easy to spot.
- *Water cut blade
*Thicker scales and liners
See more on the changes to the Second Gen below.
Mid '99 through Present are Second Generation Commanders
- *The scales and liners were made a fraction thinner
*Second ball detent added to the non lock side of the liners
*The blades are laser cut, giving them a sharper, cleaner look
*The liners were given traction grooves on the top, behind the thumb ramp
*Starting in Mid 1999 the tip was ground at a angle, keeping the blade thickness further out to the tip
*In late 2000 the tip grind was returned to the original profile
I agree with "chrisJohn" that most of the changes were probably made to better facilitate automation. I believe the thinner overall profile was due to customer requests. The Commander is a larger then average pocket knife. I know that one of the turn offs for folks was the thickness of the First Generations. Only of late has there been a resurgence of people wanting thicker knives.
I will also agree with "chrisJohn" that the First Generation Commanders are every bit as solid as customs. I guess that relegates the Second Generation to mere production knives.
I doubt though that automation is part of some conspiracy to keep from infringing on the custom line.
If it was, the SARK and SOCFK wouldn't be built as well as they are.
Again, the above information is not set in stone, just based on my experience and observations. Hope it helps.
John
P.S. I too would like to see the G10 made thicker to replicate the First Generation thickness.
