Fred.Rowe
- May 2, 2004
There is an issue that arises when the distal taper in a knife is not ground before the bevels.
If the taper is not ground first, the maker ends up fighting to keep the grind lines straight all the way through the grinding process.
If the distal taper is ground before the bevels are ground, the maker will have a much easier time, maintaining the grind lines all the way through.
I feel the end result of grinding the taper in a blade first, is the forward section of the blade will be more in tune with the overall geometry of the blade.
If you are a maker who does this differently, post your grinding process so I can see what other view points are out there.
Happy grinding, Fred
