Posting the video has raised some good questions and comments around the forum.
Let me clarify that what I like *most* about the TeroTuf is the feel and light weight, with less toxicity and greater toughness as secondary factors (although those were what led me to trying it out in the first place). It is not a pretty material, but it is a darn good utility knife handle material.
JG - Most of the handle shaping I do is with router bits with bearings that ride against either the tang (for one-offs) or handle-shaping jigs (for mid-techs). Final finish is hand sanding to round corners for comfort, which is done with a piece of 100 grit sandpaper. If you want a material that takes a high, smooth polish, TeroTuf will probably not fit that. But I haven't tried it. I like the grippiness it has at the 100 grit finish. I believe that handle shape is far more important to retention than texture, but this has just enough texture without starting to wear on the hand.
I would *not* recommend it for fine-finished pieces. But for hard use utility and grip, it's the best I've found so far for slab handles.
By way of reference, this is my typical work:
As for price, I just checked the cost of 1/4" black canvas Micarta from the supplier I had been buying from and figured price per square inch in their largest available sheet, then figured the cost of 1/4" black TeroTuf in the size I've been buying. The Micarta worked out to about $6.20 per square inch, and the TeroTuf at $5.30. Not counting shipping in either case.
Nathan - The comment about dimensional stability of the TeroTuf piqued my interest. I haven't heard of that or encountered it happening myself. What conditions cause changes? I know Dan Keffler makes sayas/scabbards out of it, as well as handles, so I would think the stability would be pretty good. But I'm curious to hear otherwise.
Chuck - I have run into some of the off-shore "Micarta", and it is indeed nasty, not to mention had a massive bow in it. This always seemed to be good stuff to me, bought in relatively large sheets from a respected supplier of handle materials of different kinds. It's canvas, in this case natural tan. I know I've seen you comment on the cheap crap before, and I respect you providing quality stuff on the market.
HHMoore - I hear you, and commented in the video that the tang shouldn't ever flex to the point that the TeroTuf snaps. But I have had Micarta handles chip out when they impacted something hard, which was one of several reasons I wanted to try something with more flex to it. Seeing makers like Ben Tendick and Dan Keffler using it led to my trying it myself, and found that I liked the other characteristics over Micarta as well.
Which is why I love TeroTuf for *my* handles.
It's relatively new in the knifemaking world, and I would like to see it in wider usage where appropriate.
