Toolin
BANNED
- Jul 19, 2001
Hey guys, I figured if I would own my Sebenza for the rest of my life that I should know how to field strip it and put it back together. Well I got it apart, used tri-flow teflon lube on the brass washers that come in contact with the blade, and put it put it back together. The blade is way stiffer then before I took it apart. I tried making the screws tighter and looser and it does not help. The blade centers perfect between the scales, and everything went together perfect. I made sure to put all of the washers and spacers back to where they belong.
I want to know if you guys have your screws in tight, and how stiff your blades are. I understand the saying "tight is tight, to tight is broke" but I also don't want the screws to fall out. Please help.
