Why is stainless steel 'stainless'?
I wrote this post earlier today in response to a question about fillet knife stainless steels. But I think it might be an interesting topic for a more general discussion. The question in the other thread that I was trying to address with the following was: are stainless steels with the same absolute chromium content equivalent in stain-resistance? For example, is 440A more stain resistant compared to 440C? Are there other factors in blade steels or their production that influence the stain-resistance of the metal? Another question raised in that thread was the correlation of RC ratings (hardness) to edge holding. These are different questions, but I am hoping here to start what I hope will be an interesting discussion of blade metallurgy.
The chromium content of a steel is the Most important single factor in stain resistance. The problem is that the percentage chromium in the alloy does Not tell you the amount of free chromium in a hardened and tempered blade. And no steel is truly 'stainless'. They will all corrode given enough time in the wrong conditions.
Iron just Loves to react with the oxygen in the air, or the acids and salts in our foods and water to form iron oxides. There are two primary iron oxide forms, ferrous and ferric. The difference between these is not important here.
My understanding is that 440A really is more corrosion resistant than 440C, even though they Appear to have the same chromium content and are identical in all other alloying elements except for carbon content.
The reason for this is that the anti-corrosion protection produced by chromium is a Surface phenomenom. Free chromium oxidizes to chromium oxide in a one-molecule thick, self-repairing, and invisibile surface layer. It is this protective coating which inhibits oxidation of iron deeper in the blade. Mirror finishes help by minimizing surface area for oxidation on the blade. It reduces the size of pits and scratches which may break the chromium oxide surface layer and allow oxidizing agent like chloride ions (from salt) to oxidize iron to ferrous oxide (red rust).
Chromium is also a strong Carbide former. It chemically combines with Iron and Carbon in making rigid crystal structures that make blades harder and hold edges longer. Low chromium steels like 52100 hold edges better than some other similar steels in part because of the small amount of chromium that is added (less than 1%). This is not nearly enough to add any corrosion prevention, however. It takes about 12% FREE chromium (that not bound up in carbides) in a finished blade to make a steel 'stain resistant'.
The additional carbon in 440C (1%) compared to 440A (0.6%) will make the blade harder and more wear resistant given the same heat treating conditions by producing more hard iron and carbon 'carbides'. But it will also soak up more of the available chromium, reducing the amount of Free chromium in the metal.
The bottom line is that it is an error to expect that the absolute amount of chromium in a steel correlates exactly with corrosion resistance. The amount of free chromium is a good predictor of oxidation inhibition. But the amount of free chromium depends on the concentration of other elements in the steel, and the ways these effect the final unbound (free) chromium in the metal.
In regards to RC scales and edge-holding: there is a rough correlation here. However, all steels at RC58 will NOT be equivalent in edge holding. Some will be better than others. This is because the RC scale only measures resistance to Penetration. Not wear resistance, toughness, malleablility, or ductility. These physical properties of steels are influenced by the alloying elements in the metal. The final combination of elements into crystals of different sizes is determined in the heat-treating steps of quenching (hardening) and tempering (softening). Every steel has its own unique characteristics. Too much is made recently of having very high (eg RC62) hardenesses. This will produce better wear resistance, but will often be associated with brittleness (low resistant to mechanical forces like bending).
Some steels make fine blades at RC60-62. Some do not. Most simple carbon steels have a nice balance of edge holding and toughness in an all hard blade tempered at RC56-58. Smaller blades for slicing can be left harder. Larger blades for chopping and prying need to be tempered a little softer to add toughness.
Some blade materials like Talonite (not really a steel at all since its principle ingredient is Cobalt, not iron) have RC values in the mid 40's. This is very very low by steel standards. On the other hand, talonite seems to outperform many iron containing blade steels in the edge holding departments. Its physical properties are quite different from steel.
It is not realistic to compare RC values of cobalt alloys and iron alloys to compare potential edge holding. Or even to compare RC values of regular knife steels to predict performance as a knife. And folks like the bladesmiths of the ABS practice differential heat-treatments, producing blades with hard edges, but soft backs and tangs, dramatically improving the overall performance of a steel.
Hope this rambling chemistry lesson helps. If I am wrong about any of this, please let me know
Paracelsus
[This message has been edited by Paracelsus (edited 10-23-2000).]
Some interesting stuff there, Paracelsus. I sort of took it on faith that 440A was more corrosion resistant than 440C, and it's nice to know the chemistry behind that. Thanks for taking the time to write that up.
Originally posted by Paracelsus, (paraphrased by Wulf):
Blah blah blah blah blah blah BLADE blah blah blah blah blah blah blah blah blah blah KNIFE blah blah blah blah If I am wrong about any of this, please let me know
To the best of my knowledge, you're absolutely right on all counts
Seriously though, thanks for posting this. The vast wealth of information I find here on Bladeforums is a tremendous resource and I owe most of my recently acquired knowledge of knives to you kind folks. Keep it up.
-Wulf
Paracelsus. I would have to agree with 99% of your conlusions.
Our testing (Q-fog) has shown that heat treated 440C does in fact demonstrate significantly better corrosion resistance than 440A.
We have also learned that 440C that was not heat treated does not have very good corrosion resistance at all.
According to the guys at "Mines", it seems that it is the Chlorine ion that attacks the carbon in steel that causes rust. the greater the carbon (generally speaking) the less the corrosion resistance.
sal
BLA,BLA,BLA......
Thanks for the explanation.
I have actually never used 440A. But as I said in the fillet knife thread I made 3 identical boning knives for a local butcher shop ATS-34, 12C27 and 440C. The only one that didn't rust was the 440C blade.
These knives were used 10hrs a day wet, bloody and every thing else that harms a knife, salt pork curring brin, sausage spice mixes etc. They were washed every night and left on a rack to dry overnight. Within a week the ATS-34 and the 12C27 blades were showing signs of corrosion. After 2 weeks the butcher took both blades out of use. After 8 Weeks of use he ordered 3 more 440C blades and is still using them. He figures that he is only touching them up about 20% as much as the previous knives he used. To him time is money and steeling or sharpening knives is a waist of his time.
Robert
Flat Land Knife Works
rdblad@telusplanet.net
http://members.tripod.com/knifeworks/index.html
Great post!
It is refreshing to read it among the "how-many-knives-do-you-have" kind of posts.
Thanks for taking the effort.
HM
What's with all them fancy words, Paracelsus? Damn alchemists always trying to confuse the good Christian folks!
The November 2000 issue of "Blade" has an interesting article on stain resistance. The article was written by Wayne Goddard but extensively quotes Ed Severson of Crucible Steel.
Severson gives a fomula for determining the amount of free chromium in steels: one part carbon will tie up 10 parts chromium in a carbide. Applying this formula to 440C, Severson says, "Therefore, the annealed matrix of 440C stainless will have only about 7 percent chromium and that is well below that of the 11.5 percent needed to be truly stainless."
The important thing to point out here is that he's talking about stain resistance in an annealed state. Severson goes on to say, "When you heat treat 440C or any 400 series grade, some of the carbide is dissolved during the austenitizing process, putting enough chromium into the final martensitic matrix to make it stainless."
So, that article seems to explain how the amount of free chromium in a steel may give you a general idea of how stain resistant it will be, but the heat treatment seems to be an extremely important factor as well. Unfortunately, it's a really complex issue; it's difficult to predict how stain resistant a steel will be just based on the numbers.
Thanks for the responses guys. My point was not really to insist that 440A would necessarily have better stain resistance compared to 440C, but rather to explain that the degree of rust prevention would depend on the final combination of elements in the steel. Free chromium is that portion Not tied up chemically in carbon and iron crystal lattices, either martensitic or austenitic. For both of these steels, if the final free chromium is above about 12%, it would be probably be very hard to tell any difference between them in regards to stain resistance. I would pick 440C over 440A everytime for knife steels because the additional carbon in 440C will produce a better blade.
Thanks for posting the Wayne Goddard stuff. That adds support to the ideas that I was trying to get across. It is very interesting that More chromium is bound up in chemical combinations in the annealed state of 440C compared to the hardened and tempered finished state.
I wish I could find a graph I saw a couple of years ago somewhere. It plotted free chromium concentration against time to rusting in salt water. The graph showed that rust resistance increased only very slightly above baseline until the free chromim concentration passed about 10%. Then the graph turned sharply upward, indicating that rust resistance increased dramatically above 12%, going almost straight up towards infinity. That means that rust resistance will not be appreciably increased by increasing free chromium from say 12% to 16%. But there would be a very large difference between finished steels with 8% compared to steel with 12% free chromium.
The main point I was trying to get at is that the absolute amount of chromium in the metal does Not necessarily predict rust resistance. It is Free chromium that matters. The amount of free chromium depends on the type of crystal structures present in the metal. And the type of cyrstal structures in the metal depends not only on its elemental constitution, but the heat treatment. The comparison of annealed 440C and hardened and tempered 440C is a perfect example.
Thanks guys!
The only thing left out (because it was beyond the scope of what Para was talking about) was the variations caused by heat-treat processes.
SOG and Myerchin have a rep for working magic with 440A
. They picked it for marine corrosion resistance, not low price. That's probably the biggest factor - so far as I'm aware, nobody else has ever tried to make a good 440A blade? Errr...I think maybe Boker did some 440A folders long ago?
Jim
I've read that copper, molybdenum and nickel contribute to corrosion resistance in some blade alloys. Is that true and if so, what's the chemistry behind their contribution?
Para,
Thank you soooo very much for this thread! I needed a relief from the "what is the best knife to kill someone" threads. I would be interested in hearing more about how various
elements is blades steels affect performance.
Thanks Para. for starting this thread.
I just moved this and some other threads from the old general forum (general forum archive3). Anybody else have anything to contribute to this topic?
Paracelsus
