Why kukri?
I often get asked "Why do you always carry that thing?"
I'll give my answer (might help the new guys), and would ask what makes you favor the kukri.
One word: versatility.
There's a lot I can do with an axe, and I love me some axes.
There's a lot I can do with a long knife.
But the kukri is good at all of them (caveat: it has to have the correct geometry).
The way it starts thick at the spine and starts tapering right away gives a lot of weight behind the sweet spot without the whole thing being heavier than it needs to be. The bevel is narrow enough to slice well and go deep, but flares enough so that when you split with it, the wood only touches the bevel. It is equally good slicing meat as wood.
An axe that is good at slicing meat will tend to stop dead when splitting and you transition from the thin cheeks to the wide eye. A good splitting axe won't slice meat well, nor will it bite deep when felling and limbing. The blade geometry of the kukri makes it good at all of these.
The length makes it a good substitute for a machete, especially if it's kept sharp and you let gravity and momentum do the work for you.
It can be used as a draw knife.
In a pinch, they make a more than adequate weapon for two or four-legged problems.
It doesn't do small detail stuff very well, but they thoughtfully include a karda for that.
What else can do all of that in one package?
Now I just have to find a better way to carry it -- so heavy off a belt! Maybe just a short loop or sash through the frog so I can carry it on my shoulder like a purse. A very manly purse.
It's called a baldric and yes - they are quite manly ;)
I personally just use a strap off a luggage bag and also tie it on my belt - distributes the weight between my hip and shoulder.
Normally though, I just strap it to my pack
Just googled baldric carry -- exactly what i was envisioning. Where would one get a nice baldric carry harness/rig?
Corp Same here. I chose the Kukri due to it's versatility. With it I get not only a long knife but a sickle (helps when cutting bedding materials), excellent drawknife ( helps when peeling logs, making tools and shelter components), axe (for splitting kindling -, cutting poles for shelters etc.),
When it comes to defensive use it makes a devastating weapon.
In my experience it is the worlds best survival knife and tool bar none. I have even used it to make bows and throwing sticks. bowdrill sets are a breeze with a kukri.
Just can't be beat.
I agree with all of the above and I'll add exotic and elegant good looks to that list. I find the khukri powerful, versatile, VERY useful and aesthetically pleasing. The khukri is Nepal's gift to all the people of the world.
I agree with Wolf's gravitation toward the exotic. Also, i think it pretty much has everything beat: a big knife can't chop as well and a hatchet is less versatile (and less durable, with their wooden hafts that are prone to breakage). Along with the karda, you have everything you need. Really, the only caveat is weight. These things aren't light by any stretch of the imagination (i'm talking about the heavier duty, chopper models that are the wilderness tool rockstars in HI's lineup).
Man, with all that said ol' moogoo is spending saturday night searching for a thick, handsome leather belt that will be the basis of my baldric rig.
Edit: Damn, thought of another caveat for me -- a khuk really isn't practical for desert survival, which i am concerned with in Las Vegas. I think if, for whatever reason, I had to hoof it into the desert to escape urban collapse, I'd grab a sturdy but lightweight machete, just to be able to clear through thorny brush and cut the tops off barrel cactus for water.
MooGoo. A kuk is practical for desert survival. I live in a desert area. A kuk works MUCH better for cutting tough ol saagebrush for shelter than just about anything I've tried. Plus (shiver the thought) it can be used to dig with. In many desert areas when you find a watersource there will be trees or brush to chop for fire and shelter. That is all without even getting into the food procurement and processing end.
My M-43 has served me very well in the desert as well as most other environments. (excepting tropical rainforest/jungle the Kuk I had back then was a BAS not from H.I.. H.I. wasn't around then)
If your are mainly only concerned with the desert enviroment the a Gelbu Special or Sirupate may be your best choice as heavy chopping wouldn't be as heavily required.
Hey wildmike, glad to know i'm not the only one sweatin' it out in the desert! Sagebrush can get pretty gnarly -- I'd definitely want a longer machete to process all our thorny, spiked flora. Plus the thinner stock would definitely work on slicing through fibrous cactus better. I'll give you game processing though -- definitely easier with a khuk or karda. But I'd pair a machete with a mora anyway, so finer tasks would be more manageable in my survival scenario.
Good thing about building a fire in the desert is that our wood (quite a bit of mesquite around here) burns hotter and longer, so i wouldn't need to chop as much wood as in other environments.
Still though, barring impossible SHTF scenarios, I'd definitely choose a full khuk rig -- more cache and style! :D
In a true SHTF situation, a khukri is exactly what I want. I even suggested changing the name of the Super CAK to the WW3 model.
I've had bad luck with most machete's. They are constructed so flimsy that they don't hold up in long term use. Now that is speaking of the ones I've found available in the last 25 yrs or so. When I was a teenager there were some very good ones commonly available.
After having used a Kukri for so many years I wouldn't go back for anything.
Every time you mention your SCAK i wince a bit out of sheer jealousy. It truly sounds like the perfect khuk. I wonder if the kamis will ever be able to reproduce the exact dimensions (notably the spine thickness and weight) for a custom order.
I think perhaps the only kami who could reproduce it is the one who created it: Sgt Khadka. Light and fast like a Sirupati but it's a big power chopper like the standard AngKhola. I consider it absolute khukri perfection.
I've been using and abusing a Tramontina Panga machete since 1988. It's been a good machete.
But the best machete I've ever used is my BK&T Patrol Machete, which incidentally is shaped somewhat like a khukri.
I really have to custom order a 20" M43 with the older-style smaller handle (with ring), hopefully with a 3/8" spine. I think that might perhaps be my khuk perfection.
I thought my 18" ASTK was perfection, but after more consideration, I think i would prefer a wider blade with slightly thinner spine.
My Bura made M-43 was one of the earlier models. 3/8 inch spine smaller handle. It is still my favorite.
However my newer model M-43 with the 1/2 inch longer handle and thicker spine only weighs 3-4 oz. more than my Bura made blade. Which is not enough for it to make much of a difference to me.
I agree with you, the ASTK's blade profile (as well as the overly large handle) just doesn't work with me.
I had a chance to get a 15" Sgt Khadka Super CAK, but missed it by that much. Next time...
moogoo: There's a guy over on the Zombie Squad forums (I think his handle is Mr. Right Wing) that lives in Vegas and a kukri is his go-to blade.
This about high desert wood is that you don't need a huge chopper since there isn't a lot of wood and it's usually small. But you need a GOOD chopper, because the wood is dehydrated and SO HARD.
Best thing to do would be to ask Yangdu if she can get the good Sgt to make you an M43/SCAK variant to your specs. Nothing is better than getting exactly what you want to fill your needs.
