- Sep 2, 2008
Left to right: Flare, K&M Matchcase with REI stormproof matches and striker, 50ml conical tube with full size Bic (more matches + striker and trick birthday candles to fill dead-space and prevent rattling), LMF firesteel, 50ml conical tube with PJCBs, char cloth.
I sometimes carry a signal flare like pictured above when outside. That's an "Orion Safety Signal Flare / Firestarter". Orion claims a five minute burn time at over 3400* (I'm guessing F), it's waterproof, it doesn't require anything for ignition other than the built-in striker cap, and would only require gross motor skills. It serves as both a fire-starter and signaling device. If I had to use mine to start a fire for immediate warmth, I'd gather appropriate kindling (which would require no to minimal prep), throw half of it together in a pile, throw the lit flare on, then pile the other half of the kindling on (5-min flare burn time) and build and maintain from there. It seems to me that if you were in a situation where you needed fire, and you needed it now, having one of these flares would greatly stack odds in your favor, assuming availability of fuel and ability to acquire and prep it. You could boost the effectiveness if you had a heatsheet/blanket to wrap up in to block wind/rain/snow and reflect IR.
My normal fire-starting progression goes (good or non-emergency conditions, full dexterity):
Firesteel + natural tinder -- if not in a rush and just bumming around or practicing tinder selection and prep
Bic -- in a rush and conditions permitting
Matches -- in a rush and conditions permitting
Firesteel + PJCBs -- in a rush and the other two have failed due to wetness, lack of fuel, or age
My "do or die" progression would go (life or death situation, severely compromised manual dexterity and mental acuity):
Flare
Bic (probably not volatile if really cold, but give it a quick go before moving on)
Matches
Firesteel + mulitple PJCBs
So, I'm curious as to why more folks don't carry something like this if you wanted to be prepared to light a fire in any condition? Is it the weight? The Orion flare I have weighs 91.9g/3.2oz, about double the weight of the K&M matchcase with matches and striker in it. I'm a guy who tends to be on the lightweight/UL side of the gear/philosophy spectrum, but I find 3oz acceptable if I feel I'll be somewhere or in some situation where more fire-starting power would be prudent. And as you can see from the picture, it isn't very bulky. Is it the fact that it's pretty much a dedicated emergency item, with no practical use on a normal outing, and overkill for the average Joe out on a day hike?
Let me note three things:
1) In general, starting a fire would not be my first step in a plan of action to combat the immediate or gradual onset of hypothermia. Seeing as a hypothetical bad situation would likely involve a serious injury, or have me stuck somewhere above tree-line, I can neither depend on thermoregulation through fire-making, nor would I prefer it unless it was the only option left to me. If at all possible, I'll opt to put on appropriate insulating layers for the conditions and get in an emergency shelter that conserves body heat. Perhaps it's different when you've just fallen in a river in Alaska in the dead of winter, where only a roaring fire will save your life? I have no experience there, but I'd imagine the flare would be even more relevant in that scenario.
2) While trying to stay warm, I'm hoping for rescue because I've a) called or signaled for help if possible, b) activated a PLB or similar locating device (I'm still looking to purchase a good one this year), c) left my plans with people who will initiate a search when I don't check-in.
3) I don't carry the flare all the time. A walk in the local park, nah. An all day outing with more risk (out of reception, less-traveled area, off-trail), yes, but it's lower on the list than appropriate clothing for the conditions and an easily employed shelter. If I lived in the frigid north or PNW, I'd carry one more often than I do here, in relatively mild CA.
I'm just thinking that as far as keeping my options open goes, with regards to thermoregulation through fire, I'd much rather use a signal flare to get a fire going in a truly crappy situation than dick around with other seemingly less surefire methods. Thoughts?
ETA:
I guess safety of storing a flare could also be another concern?
