In the case of the Sebenza components, anodizing is the process by which a layer of oxide is formed on the surface of the titanium by electrolytic means. The "color" that your eye is perceiving is a function of the thickness of the oxide when light hits the surface of the anodized Ti, depending upon the thickness of the oxide, a narrow band of the light spectrum is reinforced, other wavelengths are destructively interfered with (like multi-colored interference patterns that you see on an oily surface, etc.) The "color shift" that you're describing is either due to the thinning of the oxide caused by the wear of ordinary handling, or the addition of finger oils on top of the oxide, effectively making that top layer thicker. Either of these conditions cause a shift in the frequency band that is reinforced, which in turn causes a change in the color that your eye perceives. Over time, the oxide layer can get worn away completely on "high traffic" areas of the anodized surface due to handling, and as a result, you'll lose the perceived color. CRK's anodizing in the "valleys" of the titanium surface significantly helps to protect the oxide layer by reducing physical contact to the surface, and thus prolongs the colors perceived.
Hope that helps.
