Wider stones magnify errors in the angle of attack between stone and edge. The wider the stone, the more susceptible the bevel is to off-angle grinding, where each side of the stone sits higher/lower and does not produce an even bevel.
Up to 1.5 inches seems to work ok, any wider and issues start cropping up. I experimented with diamond and ceramic plates a couple years ago for the exact reason you cited - thought it would be faster.
Think of it this way: For your 1" width of the stone, each 1° of off axis rotation moves the far side up/down about 0.017", for a 2" stone the error doubles to 0.034" - this is visually noticeable. 3" stones are essentially unusable without completely destroying the consistency of the bevel.
Part of this is how sharpening is different moving the stone vs. moving the knife. 3" wide benchstones work great, 6" wide bench stones are difficult and have the same issues as larger guided stones.
