Depends on what you are doing with the belts. Nice sharp belts cut faster and cleaner than dull ones. If you are trying to clean a blade up after heat treat, then a dull belt may come in handy. However, be careful not to ruin your heat treat because dull belts overheat much faster.A beginner here.
It is always said to use a new, sharp belt on the important parts of the knife, such as the bevels.
I am not disputing this, but want to know the reason why, please. Is a worn 60 grit not just the equivalent of an 80 grit, etc.?
I see where you're going with this, but no, the grit doesn't wear down evenly as you grind and you can still have the odd 60 grit chunk that will leave a deep scratch. But yeah, it'd be great if that's the way the world worked.Is a worn 60 grit not just the equivalent of an 80 grit, etc.?
Adam - that is one of the best comparisons I have seen in a long time.No a worn 60 grit is not equivalent to an 80 grit, just like a 20" flat tire is not equivalent to a 15" tire
