In a lockback or slip joint folder, it is normal not to have washers.
In any type of linerlock or framelock folders, where a detent ball is used to hold the blade closed, some space must be provided between the inside of the frames/liners and the blade tang. This space is required to account for the protrusion of the detent ball above the surface of the liner/frame.
For example, I use .028 protrusion of my detent ball. So, I need .030 space between the frame and the tang of the blade. If the space is not provided, the detent ball will bind against the tang of the knife when it comes out of the dimple (detent) in the blade tang. This is because when the ball is riding on the tang, the outer surface of the spring is now in the same plane as the outer surface of the frame (or liner). The .002 additional clearance I provide keeps the outer surface of the locking bar away from the inner surface of the handle material that is attached to the frames. In a knife like the sebenza, where there is no scale covering that portion of the frame, the washer thickness could exactly equal the ball protrusion.
To further elaborate on some of the comments made here-Really high end lockbacks and slipjoints usually have raised, circular pads around the pivot pin. These pads are created by scraping the inside of the liners to a depth of .001-.002. around the area of the circular pad. This in effect, creates the same bearing surface as a washer, only thinner-So thin that if properly done, you can't really notice them. This scraping assures that there is no contact between the visible parts of the blade and the inside of the frames, eliminating radial scratches. Find a picture of a folder made by Tim Wright and you'll see what I mean. His knives can be disassembled, and you can clearly see the pad-up area in a photo of one of his knives in a disassembled state.
As to washers creating play, well, that's simply not true. Flat and parallel surfaces (blade/frame/washers) will mate up perfectly, and as long as the clamp-up provided by the pivot screw(or peened pivot pin) is correct, there will be no play whatsoever.
If you really want to get fancy, you can use roller thrust bearings like I do, which can be clamped up and provide almost no friction when the blade swings open, yet provide absolutely no sideplay.
