Personally I like the look of bare metal vs coating. There's some exceptions, but not many.
+1
One of the things I think that draws me to knives (along with the Obvious use of a great/functional tool) is the appeal of satin bare metal. I like the look ..... and feel.
Coatings....... :barf: - I think coatings look terrible even new, let alone after they get easily MORE uglified. If I "MUST" pick a coating that doesn't make me terribly ill, Sage is OK. But, I will take SATIN EVERY TIME - quickly, easily without ANY thought or ANY hesitation!
Apparently, "Some" people like the looks of coatings. But, I am NOT one of them. To me, coatings "Look" very Mall-Ninja/Tacticoooool. :barf: - Sorry to say that when I know "some" like the look of coatings. But, that is just my honest opinion. I don't really understand why anyone likes the "look" of coatings. Let alone "Choose" gunk coated on a blade over a nice looking satin finish. What is to like?
I don't think MOST of the people who buy Busse and kin knives have any need for the non-reflective properties that coatings provide. But, I can see and appreciate where "Some" of those in the military WOULD need and appreciate the non-reflective benefits of a coating.
If "I" were in the military and in a front-line battle scenario, I might have a different view on coatings. But, I am not in the military. I am not concerned about scaring the Sheeple or wildlife either. But, from what I have seen, Sheeple seem to fear black blades more than satin. I don't understand Sheeple either.
By removing the coating you reduce the friction while cutting.
+1
Coatings don't affect "all" cutting tasks. Shaving hairs only involves the very edge of the blade. Or if the material being cut is no thicker than the blades edge - chopping small twigs or somthing (????). Or if the material naturally pulls "Away" from the sides of the blade - like splitting certain dry wood in "some" cases. But, if "Through" cutting were the material "Drags" up along the sides of the blades, Satin finishes are smoother and produce less drag/resistance than most coatings. Although, at some point, the coatings tend to wear reasonably smooth at the high use areas of the blade. Once you get your partially worn blade to the partially coated stage.
With any discussion of certain "through" cutting, I would feel an obligation to point out the values of a good convex edge as well. The "corner" created between the transition of the edge to the primary grind causes more drag and resistance when through cutting. Without such a corner, Convex edges cut smoother when "through" cutting. Again, when just shaving hairs or cutting that doesn't involve drag or resistance against the transition corner, there isn't any real noticable difference. But, slice/chop deep into some green wood or similar cutting where the material being cut drags or creates resistance against the raised transition corner and/or sides of the blades and a good convex edge will bite much deeper and easier. :thumbup:
With SR-101, I actually think coatings "Do" provide protection against corrosion. But, satin is generally easier to clean. And satin SR-101 is not that hard to protect against corrosion if you know about it and stay a bit on top of it - keep it dry and keep it coated with Ren-Wax, Mineral Oil or similar lube.
I prefer to use satin finishes with food. I don't generally care to cut my food with coated blades and all of the gunk trapped in the coating. :thumbdn:
Raw unprotected SR-101 will patina VERY quickly when used to cut food. But, the patina doesn't hurt anything. Kind of like an old cast-iron skillet. Patinas look nicer to me than coatings as well.
When the coating wears away from the blade from abrasion and scuffing, you are just left with a progressively uglier blade that you can't do much about other than send back to Busse to have re-coated at some point.
With satin finishes, it is pretty easy to restore the finish with Scotch-Brite belts/pads or similar.
I wish ALL Swamp Rat knives including all SR-101 knives would be released with a Satin option!!!!! :thumbup:
INFI..... INFI doesn't need ANY coating. There is NO benefit to me for putting a coating on INFI. INFI can and will rust, but it is pretty darn resistant to rust. It takes some effort to get it to rust. Generally, I don't feel INFI needs wax or lube on the blade for corrosion protection. The only reason for coatings on INFI is because Jerry charges more than I can afford or justify for Satin INFI. $200 - $330 upcharges for a satin finish is not justifiable to me.
I don't care about LE numbers. Keep the numbers and only charge about $20 - $40 upcharge above CG finishes for satin finished blades.
$10 - $20 more for Competition edges (* But, NO more De-Carb! :thumbdn
