- Jan 4, 2016
My question is about how the geometry/angle will change from heel to tip because the tip is lower in elevation. If you follow the W.E. directions the tip will have a more obtuse bevel as a result.
When I set up a blade in my W.E., I imagine a straight line between the point and the very heel of the edge and I set that imaginary line parallel to the base. This "averages out" the geometry along the length. I set the actual angle at the crown, centered over the clamp.
Incidentally I also find this approach aids in adequately clamping full flat grinds, such as the PM2 blade. Dropping the handle and raising the tip allows the clamp to work better, clamping on the full width of the jaws, as well as evening out the bevel along the length.
Anyone else do this? I've never seen this technique recommended or discussed. All W.E. videos and knowledge base articles have the spine horizontal to the base.
Curious if I'm the only one who drops the handle in their setup.
