[Wicked Edge] Cannot get the curves sharp?
Finally upgraded to a Wicked Edge. I have watched the videos, read many threads, practiced on a few kitchen knives, and moved on to my folders. The issue that I am having is that I cannot seem to get the curved part of any blade sharp. The straight part of the edge will remove hair without touching skin, but the curve near the tip will barely slice paper cleanly. This has now occurred on 3 different knives, with varying lengths and blade shapes.
Sorry for the newb question, but does anyone have any suggestions? :confused:
I don't use a Wicked Edge, but the same sharpening fundamentals always seem to work, whether I'm using my Lansky, DMT Aligner or freehand-sharpening. Here are some suggestions:
1. With many blades, as the edge approaches the tip and curves upward into thicker steel near the spine (usually), the edge angle often will become more obtuse (wider). It may take a while longer to re-bevel to a full apex in that portion. Use a Sharpie or other marker to darken the edge bevel, and verify the edge is getting apexed in that portion.
2. Due to the curvature of the edge in the belly, much more pressure will be exerted against the very narrow portion of the edge making contact with the hone. As the contact area becomes smaller, it's critical to lighten up the pressure substantially in that portion. Too-heavy pressure will be counter-productive there.
3. For me, I find it helpful to use very, very light sweeping strokes along the curved portion, following the cutting edge, as if gently sweeping dust from the edge in that section. The contact is much more gentle this way. This works much better than continually scrubbing perpendicularly into the edge in that part of the blade. I think I've been lucky, in that the belly of the blade on my knives is usually the sharpest portion of the edge, for me. That's usually the portion of the edge that bites me first, when checking with my fingers. So, I know this technique works. ;)
Hope this helps. Good luck! :)
David
Have you used a sharpie to be sure you are actually forming the apex on the curves?
David
Obviously I'm not the op, but I have had the same issue with other systems. I think you're right on the money David. Thanks. :)
Moving the blade back in the vice, combined with David's advice, fixed me right up. These things are freaking lasers now! :thumbup:
^:thumbup: Agreed David got me set in the right direction with my DMT magnaguide. Thanks again Dave!!
David offers excellent advice, but you should start with areads advice, find out where on the blade you're hitting with that stone, then adjust as needed with what David said...
