If your goal is to simply “clean up” an edge, the 5/3.5mm strops will work just fine. It won’t “polish out” the 600g scratches, but it will clean up residual burr, and refine the edge a bit. You’ll easily get an edge that will shave arm hair, cleanly slice paper, etc.
So, what your definition of “working edge” is, depends on whether or not you should get the 800/1000g stones, but you don’t need them for the strops to be effective.
As for the 2nd part, of lowering the angle, my answer is try both ways and see what works best for you. A strop can in theory, “round” the edge, so if it’s soft it can “dull” it. W.E. strops are pretty thin, and don’t have a lot of give, so some get better results at the same angle, others lower the angle, others lower the angle and increase the pressure. Beauty of sharpening your own knives... you get to experiment. It takes seconds to reestablish an edge and try a different technique, if one stropping method doesn’t work well.
W.E. made a recent video showing some of the results from the 600g stone (no stropping)...
