*Rolls Up Sleeves...Seriously*
I just purchased a Wicked Edge Pro Pack II about 2 months ago. I have sharpened roughly 30 knives ranging from cheap Chinese Crap Steel to S30V, ELMAX, CPM-154, etc. This is going to be my attempt at providing you with the most detailed description of my process possible. Keep in mind I do have and angle cube and the upgraded ball joint arms so my steps may be slightly different from yours. I also highly recommend the angle cube and ball joint arms.
Here we go!
I start by positioning my knife in the clamp so that the belly and tip are quite close to the clamp. Usually with the middle of the blade positioned slightly back from the middle of the clamp. I have found that this gives the most consistent bevel along the entire edge of the knife. By that I mean you don't end up with a more acute angle towards the tip.
Then I set my arms to the angle that I want to sharpen at, and use the angle cube and micro adjusters to get the angle to within 0.05 Degrees. I then apply sharpie to the entire length of the current bevel.
*Optional* I use some foam mat material to prevent my knives from being scratched, as well as hold full flat ground knives in place.
Now for the sharpening. If I plan on doing a complete re-profiling, I will start at 100 grit and move up from there. If I plan on matching the current bevel, I will start at either 400 or 600 grit. I NEVER build up a burr until I reach 600 grit, and even then, I sometimes never build up a burr. The reason for this is because when I first purchased my WE, I would build up a burr at 100 or 240 grit and this ended up causing my bevels to be slightly off center. To re-center my bevel would be a waste of steel, so I simply leave it until the next sharpening. Steel waste is another reason I don't build the burr until the higher grits. Also, once you have built your burr at 600 grit, you do not need to do so again. The burr simply proves that you have apexed the edge. You don't need to prove you have apexed it more than once, and doing so wastes steel and sharpening longevity.
I prefer the up and away sharpening motion. However, if I am re-profiling may use a scrubbing motion to speed things up. I also, rarely count my strokes except when stropping. I go simply off of the sharpie line I have drawn on the bevel. If I do 50 stokes on one side, and see that the edge is apexed, and do 50 strokes on the other and see it is not apexed, then only 1 side needs work. Though I will do occasional strokes on the opposing side to remove a burr if one forms. I will also always finish with up and away strokes regardless of if I was using a scrubbing motion. This is to keep a uniform grind pattern which will help with polishing.
I will move up through the grits (100>240>400>600>Etc.) and stop at either 600 then strop if I want a toothy edge. Or take it all the way up to 0.5 micron if I want a polish.
After I can see visibly that I have apexed the edge, or I know I built a burr. I will do enough strokes with the next grit until I can see that the grind lines from the previous grit have been removed. This usually takes a fraction of the time that it takes me to apex the edge. For example: If I am sharpening a hard tool steel, and it takes me 20 minutes to re-profile the edge from 40 degrees inclusive to 34 degrees inclusive at 100 grit. It will only take me ~2 minutes for the rest of the diamond stones to slowly polish out the grind lines of the courser stones (ceramics and strops are different, and will be explained next).
Once I have apex the edge all the way from heel to tip, and have got a consistent grind pattern at 1000 grit (if I'm polishing) I will start on my 1.5 micron ceramic. With the ceramics, I use a scrubbing motion to slowly polish the scratches out of the bevel. I will usually only focus on one side and then the other because the ceramics do not wear away enough material for me to worry about altering the bevel at this point. I will finish with the ceramics using up and away strokes like I did on all the other grits. I then move up the next higher grit ceramic and repeat.
Stropping is the final step in the process for me. I start with my 1.0 micron strop (even though my fine ceramic is 0.6 micron). The reason for this, is because the strop will contact more of the bevel than the stones. Even if I know I apexed the edge, the rigid stones can occasionally miss little areas (you will see where there is a tiny black mark on the bevel from the sharpie). I use mild pressure to start with the strops, then ease up till I am barely using the weight of the Wicked Edge arms. This will help to polish.
After thoughts and tips:
- Don't apply too much pressure when sharpening. Just the weight of your hand should be plenty, any more is unnecessary.
- You can check the bevel by running the edge of your finger nail along the edge of the knife to see if you are polishing the edge entirely.
- I usually have some phone book paper next to me when sharpening to check my sharpness at all stages. This way I can gauge if I screwed up at some point and dulled my edge.
- SHARPEN THE WHOLE LENGTH OF THE BLADE ALL THE TIME! Do not make the mistake I did, and try to sharpen only a section of the blade just because the rest of the edge is apexed. I did this and ended up with a mild re-curve in my Socom Delta (it will piss you off if you do this).
- I see people talking about microbevels and using them to improve results. This should not be needed if you are sharpening properly. If however, you would like to increase edge strength then a microbevel may be advantageous.
- Wipe the blade when you finish with a stone/ceramic/strop. This helps to prevent cross contamination between your stones. It will also help with grind line consistency.
-10 Knives may or may not be enough to break in the stones. Are we talking 10, S30V knives? Or 10 ,420J Chinese kitchen knives?
-Lastly, for pure hair splitting sharpness you want to sharpen at a very steep angle (30 degrees or steeper) and you DO NOT want a microbevel. The acute angle is what helps the edge to split a hair, a microbevel makes the edge more obtuse.
Hope this helps, all the info here is from my own mistakes and challenges I had with my Wicked Edge when I first bought it. I might also suggest watching X4CTO's "Wicked Edge Tips" video:
https://www.youtube.com/watch?v=ZimtzImyrTI if you don't mind his sexual innuendo.
P.S. The reason your edge no longer feels sticky when you use the ceramics, is because when you use the ceramics you are essentially removing the teeth and refining the edge. It will not grab your skin as much, however it will improve the edge's ability to push cut paper and split hair.
Edit: Lucky for you, I was bored and felt like typing a 1300 word post at 2:00AM
