- Nov 16, 2013
Guys, I need some help with sharpening my knife and ensuring that I don't ruin it in the process. I own a Microtech Custom Socom Delta with a tanto edge.
The problem that I have is my Wicked Edge will "only" go out to a 35 degree angle. The Tanto portion of my blade has such thick metal that it appears to need about a 45 or 50 degree angle to put a "nice looking" edge on it. One that is close to factory.
Here is a picture of the knife in question. See how nice the "factory secondary grind" looks on it? The grind is nice and low profile. That way your eye is drawn to the beauty of the knife and not to some obnoxious secondary grind.
Here is a picture of how thick the metal is at the tip. (It's the "thick looking" one on the left)
Here is what I DON'T want it look like. See how I (nearly) ruined the look of this knife by widening out the grind on it at 20 degrees.
Here is my Custom Knife sitting in my Wicked Edge. You can see on the tanto portion of the blade, I colored the edge black with a Sharpie Marker and the grinding stone is not even touching the marker. It only started to grind the side of the blade and "widen out the grind".
I sent Wicked Edge (the company) the last picture and asked if they offer something to help me get past 35 degrees. They said they offer no such thing.. Furthermore, they said they only suggest using a 25 degree edge or less.
Considering the exorbitant cost of a Wicked Edge System, I would have thought they'd cater more to the custom knife market and at least offer wider angles..
Right now, my only option that I can see is to send it back to Microtech to have them sharpen it. But I'd rather do it myself.
Does anyone know of a sharpening system that goes out to 45 or 50 degrees? Or is there a different solution to my problem??
Thanks A Lot In Advance!
