I'll confuse you some more: many parrot the phrase "no pressure, awwwwkkk, Polly says no pressure" but then Clay (inventor and owner of Wicked Edge) reports using so much pressure on the strop paddles that the entire base is rocking back and forth coming off the table. Other people using the WEPS as well use a lot of pressure; some folks have noted how, back in the day, the old time barbers would strop the razor prior to giving you a shave, and they always used plenty of pressure.
What I've found with the WEPS is that you have to try things for yourself. For example, with stropping, the quality and state of the edge that you have created prior to stropping greatly influences the results you will get with stropping. So the stropping technique that is perfect for me might be perfectly awful for you. There's only one way to find out.
You know that there is a WEPS forum, with a section devoted to stropping?
