- Sep 29, 2008
Hi guys
Got a technical question for the sharpening boff's: although, It may be completely irrelevant.
Would there be any difference in "edge lasting" between a sharp polished edge and a sharp rough edge?
Example: If I use only the brown stone on the spyderco sharpmaker, to make it hair popping sharp, and not the white honing stone. you can feel it has a rough sharp edge, know what i mean?
Now basically this question derived from the S30V debate.
It seemed that there is a possibility that S30V "chips" microscopically causeing it to go blunt. Although it "IS" a high wear resistance metal due to Vanadium, it chips easy?
So, basically, if there is a rough hair popping sharp edge, can the "TINY" little teeth "chip off" causing it to go blunter, compared to a polished smooth edge with no "microteeth", and a completely flat area to increase surface area?
I know this is over the top....but who gives a sh#t, I would like to know if its a absolute fairy tale story im making, or if its possible?
