Wiggles in my Sebenza!!!
OK, this is weird...when I hold the lock bar out of the way and open my Small Sebenza, I can wiggle the blade slightly from side to side by holding the tip.
All screws are fully tightened.
Has anyone experienced this before? I thought Sebenzas had NO WIGGLE!
BTW, when I engage the lock, no wiggling.
Is this normal?
I checked two of mine, one absolutely new, no wobble even with lock off, the other bought used, a small amount wobble with lock off.
I wouldn't worry, but that's up to you.
Check that the pivot screw is tight.
I have a large reg sebbie from the passaround.
There is slight wiggle as you describe.
When locked it's tight as.....
well, tight.
Tom
