Wilderness Survival kit, opinions please
Here is my wilderness survival kit. Any suggestions, or additions?
http://pg.photos.yahoo.com/ph/hwtsauer@sbcglobal.net/album?.dir=/2cf9
Here is what is in the kit
1 .RAT-7 D-2 knife with Spec-Ops survival sheath
12ft para cord wrapped on sheath, leg lanyard, and lanyard on handle
2 .Tool Logic pocket knife, Fire model
3in blade, half serrated, whistle, and flint rod, 2ft parachute cord tied to RAT Sheath (forgot to put in the picture)
This is a very nice tool. It can be used for so many tings. It is very handy and a minimalist kit in its self. If in a serious survival situation this knife would go on around my neck with the para cord to insure that I would not be separated from it.
3. Altoids can, in sheath gear pocket, this holds all of the other little stuff
lid can be used as a mirror. This can also be used to cook in and make a lantern or candle to keep a snow cave warm or cook over if needed.
4. Spark-Lite and tinder
This is not the best flint that I have ever seen but it will do a good job should I run out of matches. It will be better than friction methods. It was chosen because of its small size, I think that I would rather have a long rod of flint but should I lose my knife flint would not do me much good.
5. Reynolds Oven bag, used as water container.
This will hold much more water than a condom, but takes up a little more space. I think that it is worth it because it is much more versatile and puncture resistant.
6. Wind/water proof matches
“Life Boat”, 20x with striker. These are good matches and burn very hot, however some of the wood stick parts tend to crack or be weak. Make sure you select only the best to go in your kit.
7. Wire Saw, British SAS, with parachute cord instead of key rings
This is for sawing wood, bone, and soft metals. Very handy and compact. Uses are numerable, everything from fire wood to shelters to traps.
8. Jig saw blade,
It has 14tpi (teeth per inch) and the back side sharpened into a 2in tanto blade, over all it is almost 3in long. I found out that the Black & Decker jig saw blades are much stronger and thicker than normal ‘hack saw’ blades. It will take some time to sharpen the back of it and it will take a ‘tanto’ form. I was able to sharpen mine to the point that it will shave hair off my arm. This can be lashed to a stick, bone, or antler to create a very handy cutting tool. The saw can be used for trap building or anything small that needs to be sawed. The blade is to be used mostly for small cutting jobs ( small game, fish, or traps) when ever fine control is needed and a 7in blade is too much
9. Portable Aqua.
24, in a straw for protection. This with the Reynolds bag and you have clean water. It will only clean 3 gallons but its better than nothing.
10. Sewing kit
15 assorted threads
2 small needles
1 large needle to use as awl
1 curved needle, 2 small brass pins
4 buttons, 4 small safety pins, 1 large safety pin
11. Fishing kit
1 roll of 25ft 20lb line
18 BB size split shot sinkers
10, size 10 gold hooks
10, size 8 hooks
5, size 6 hooks
1, size 7/0 hook, to use as a gaff, wrapped with small wire to attach to pole
1, salt water hook ( 4in long) as large gaff, wrapped with small wire to attach to pole
-the gaff can also be used on small game, reptiles, and birds
If you are where it is likely to catch fish you should have a extensive fishing kit, not just a few hooks and some line.
12. Snare Wire, 28gauge galvanized 1roll of 17ft, 1 roll of 7ft
another roll of smaller wire for misc uses, too small for snares, but would work for birds.
Just like the fishing kit, if there are a good deal of small critters running about bring as much snare wire as you can fit in your kit. The more snares you put up the better chance you will have of catching something.
13.Razor blade
Just thought it might come in handy. Takes up very little space. It can also be made into a compass if magnetized and suspended by a string it will align with North and South.
14. Large Paper clip
15. Large safety pin
Used as a pin, removing splinters, can be broken and made into a compass or fish hook
16. Meds, 2 Tylenol 500mg, 6 Benadryl in small plastic bag, and 2 multi vitamins.
Tylenol is good for fevers, but not an effective pain reliever. The Benadryl is for allergic reactions to insects, foods, or anything else. The vitamins are just incase I end up out for a while, it will take some time for vitamin deficiency to take place.
17. Dryer Lint
It is used to keep everything from moving around but it also makes some very good tinder for fires and can easily be lit with the spark-lite.
18. Roll of floss, waxed.
Very strong and can be used for stitching wounds, clothes, fishing line, or any other need for a strong string.
Things not in altoids tin
-Jet Scream whistle
-Princeton tech 5 function key chain led
-35 mm film canister with 8 petroleum soaked cotton balls
-magnesium and flint fire starter with jigsaw blade
-diamond sharping stone with handle cut down
Not sure if anyone can see the picture, did I do it right? If not can anyone help? Thanks
Wade
Nice kit, but I can't see the pics.
I notice you have nothing for shelter in there, a space blanket might be nice.
I find a small Bic lighter well worth the space/weight
Several ranger bands (cut inner tube) are easy to slip over the Altoids tin (help keep it closed) and are awsome for starting fire. Use the smallest bit of of cotton/petrolroleum jelly to get a flame from the spark, then light the band. Helps conserve the valuble tinder that will only light with a spark. a birthday cake candle or two can be nice too.
Will
Along with a space blanket, you might want to consider adding a HD 55gal drum liner or something similar for shelter. I keep them in all of my kits and have lashed one to my Becker and USAF PSK sheaths.
Not sure how safe it is keeping Potable Aqua tabs in a straw, from everything I've heard about them they will react with about anything but glass & teflon. Equipped To Survive websight has an article about this IIRC.
Gene :D
Thanks for the replies. I have a small first aid kit that is kept in my pack, along with a space blanket, poncho, and a million other things. I cant fit much more in the altoid box. I will try to work on the picture issue. thanks.
OK, I think the pictures should work now. Let me know if they do or dont please. Thanks
I would recommend agains the Potable Aqua in a straw. The iodine will evaporate and react with lots of stuff in the process. I use small foil packets of Potassium Permanganate (KMnO4) for emergency back-up water treatment. Just today I picked up 90 chlorine tablets, Clor-In 1, that treat one liter per tab and they come in a pill/bubble pack, very compact.
In my emergency kits I tend to devote very little space to food gathering. The one main concession I make to food is salt. In a hot climate like Brazil it is essential. Mac
I have had good luck with the straw and portable aqua. I stacked them in the straw folded the ends, stapled them, and added a drop of glue. they are water tight and have not reacted with anythign and have not changed colors. I have had them in the kit like that for eight months and plan to change them in the next few months.
Once exposed to air, they lose their strength rapidly (ie a few months). Carry Katadyn Micropur tablets instead.
Will
Another vote for Katadyn Micropur MP-1. It's relatively expensive (I think $15 for 30 tablets or something like that), but it will kill things that chlorine, iodine, and other regular water purification tablets won't touch. One thing you shouldn't skimp on :)
how small are the Micropur tab's? Are they even close to as small as a polar pur tab?
The Micropur tablets are pretty small, and extremely effective. I would highly recommend carrying a 1 oz bottle of iodine, or better yet, betadine also. The problem with tablets is that they generally treat a liter. If you have to scrounge water, and only get a half a liter, what are you going to do, cut a tablet in half? Read the package on the Micropurs, you do not want to touch that stuff. With betadine, you can just put in 3 drops instead of 6 or whatever the dosage is.
