G10 is the most stable and stiffest. It's also the heaviest. It is the most abrasive to work with, but surprisingly it has poor abrasive wear resistance. It looks good on a knife, but I don't like it on my own because it's unnecessarily heavy and other materials offer a better grip.
Micarta is significantly lighter than G10, and a little more flexible. It's still much stiffer, stronger and more dimensionally stable than wood (the material that's been used successfully in this application for millennia). It offers a good grip even when wet or goopy and it wears better in a gritty kydex sheath. It has poor impact resistance compared to other synthetics (not much better than wood) and can crack or chip if used on a throwing knife or similar. Phenolic is not inferior to epoxy, it's just different.
Tero Tuf is the most flexible (least stiff, not a good thing). It's durable and apparently it has the best grip when your hands are sweaty. It's on the knife that won the last two world cutting championships. It's attractive from a manufacturing point of view because it's nontoxic and non abrasive. To me, the biggest problem is poor dimensional stability. It can shrink away and allow a full tang to stand proud more than the others which requires some special thought on how and where it is used.
They're all quite good and we're fortunate to have them, but there are relative pros and cons to all of them.
So it is described as polyester resin with polyester fabric. My searchfu is weak, can't find an MSDS. Polyester resin in this context almost certainly means an unsaturated polyester which is then cured with either styrene or methyl methacrylate. Think of it as the resin used to make gelcoat and 'fiberglass' for marine applications. The shrinkage thing is surprising to me, AFAIK boat hulls don't shrink, so why should this TeroTuf?
