Will going from Fine DMT stone to Extrar Fine make much of a difference?
I have tried many different sharpening stones over the years, and I have found the DMT benchstones I now use to be my favorites so far. I use a Coarse stone and a fine stone. The fine stone I think is roughly 600 grit. I use mostly folders, none of which see really rough use. My question is whether or not I can justify the expense of buying the Extra Fine, which is about 1200 grit? Has anyone here noticed a big difference between the Fine and Extra Fine DMT stones?
Thanks for any thoughts on this.
I got a set of DMTs for Xmas. Two 8" plates. One Course/extra Course and the other Fine/Extra Fine. Personally I like the transition from the fine to Extra Fine. It smooths out the scratch pattern and refines the edge a little but it does not polish. I use a Spyderco Ultra Fine for that.
There IS a noticeable difference between DMT's Fine and EF. Only question is which finish you'll prefer. I've become pretty fond of the Fine (600 mesh/25µ) DMT, as it's versatile enough to use both for re-bevelling and for finishing, with most small-to-medium-sized blades in any steel; makes a pretty ideal 'one-stop' solution. The EF is obviously finer, and might be preferable along with the EEF and finer hones and strops for edges intended for push-cutting, and if you're pursuing polished bevels with a more complete grit sequence. The EF could also be handy for quick edge repairs on small & thin blades (like traditional pocketknives) in simpler steel. Even then, in my own uses, I'm even using a 'Fine' DMT pocket/keychain hone for blades like those. Sometimes the really small blades benefit from a finer edge finish though, and an EF will also minimize how much precious steel is taken off of those already-small blades.
If you're pursuing polished finishes on BIG blades, the EF in a bench-sized hone might work for you, as part of the sequence. If your blades aren't very large, or if you're just looking for nice, quick working edges on EDC blades, a bench-sized EF might be more hone than you really need; you might do well enough with a smaller hone in the EF grit. Save the expense of the bigger bench hones for heavy grinding jobs in coarser grit; that's where the extra surface area really pays off. Once the bevels are set, it doesn't really take much surface area to refine most edges further. BUT, if your motion and technique are tuned to using a larger bench hone, then you still might be better off using one in EF.
As mentioned, the EF won't polish, but will leave a very refined 'satin' finish. With high-wear steels, the EEF DMT approaches polishing, but will still be somewhat hazy or cloudy; scratches will be deeper and more apparent on less wear-resistant steels. All of DMT's hones leave varying degrees of wicked-toothy 'bite' in the edges they produce, which is the best reason to use them. From at least the 'Coarse' (325 mesh/45µ) through the EEF (8000 mesh/3µ), any one by itself can produce great working edges, with minimal stropping only to clean up the burrs.
Might also look at the pics in post#2 of Jason B's 'The first sharpening' thread (link directly to that post below), to SEE the difference in finish between the Fine and EF DMT hones, and read Jason's impressions of changes in sharpness. I sort of think of that thread as the definitive example of what can be done with DMT's hones and stropping pastes, if your skill & technique are up to it. ;) :
http://www.bladeforums.com/forums/showthread.php/732635-The-first-sharpening?p=8091102#post8091102
David
Thank you for the help with this.
My main folders which I rotate the most are the following: Buck 110, Large 4 inch Coke Bottle type, Large Case Toothpick, ZT 0200, BM Bedlam, and a Boker Resurrection.
I have been using DMT for years
I use the DMT Aligner to re-bevel Queen D2 blades
I go from EE Course to E Fine
I maintain all my slipjoints blades by stropping with white compound
If the blade needs touching up then a couple of swipes with a 20 year old DMT E Fine folding paddle
I only use DMT Fine on soft SS like Victorinex SAKs and paring knives, where with a 500 cut veg prep, the edge is lost fast and a couple of swipes with the fine puts it back, and the edge does not last long enough to warrant E Fine
I cannot tell you anything about scratch patterns or polishing
But DMT Extra fine will give me a hair shaving sharp on all my blades
I would highly recommend the DMT E Fine as a final stone when using DMT stones
Yes, but more importantly stropping will make an even bigger difference. I've used dmt's fine before. It's not really that fine, but neither is 1200 grit compared to what you can get out of stropping. I wouldn't stop at 600 for any reason.
